Differences
Link to this comparison view
Next revision
Previous revision
en:sidebar:remoteapi:apiref:item:update_name [04/02/2013 12:08]
zuve
en:sidebar:remoteapi:apiref:item:update_name [29/11/2013 13:31] (current)
Line 2: Line 2:
 ====== Rename ====== ====== Rename ======
-To rename item use command **core/​update_name**: ​+To rename ​an itemuse the command **item/​update_name**: ​
 <code javascript>​ <code javascript>​
 svc=item/​update_name&​params={"​itemId":<​long>,​ svc=item/​update_name&​params={"​itemId":<​long>,​
Line 10: Line 10:
 ===== Parameters ===== ===== Parameters =====
 ^ Name ^ Description ^ ^ Name ^ Description ^
-| itemId | ID элемента ​+| itemId | item ID |
-| name | новое название ​(должно содержать более ​символов) |+| name | new name (at least characters) |
 ===== Response ===== ===== Response =====
Line 17: Line 17:
 <​code=javascript>​ <​code=javascript>​
- "​nm":<​text>​ /​* new name of item */+ "​nm":<​text>​ /​* ​item new name */
 </​code>​ </​code>​
