Differences
Link to this comparison view
Next revision
Previous revision
en:sidebar:remoteapi:apiref:item:delete_item [25/01/2013 14:42]
zuve
en:sidebar:remoteapi:apiref:item:delete_item [13/02/2013 06:39]
alek
Line 1: Line 1:
 {{indexmenu_n>​2}} {{indexmenu_n>​2}}
-====== ​Deleting ​======+====== ​Delete ​======
-To delete item use command **item/​delete_item**: ​+To delete ​an itemuse the command **item/​delete_item**: ​
 <code javascript>​ <code javascript>​
 svc=item/​delete_item&​params={"​itemId":<​long>​} svc=item/​delete_item&​params={"​itemId":<​long>​}
 </​code>​ </​code>​
-:!: The example ​with this request ​you can find in chapter ​[[../​../​codesamples/​update_item]].+:!: You can find an example ​of this request in the sample ​[[../​../​codesamples/​update_item|]].
 ===== Parameters ===== ===== Parameters =====
 ^ Name ^ Description ^ ^ Name ^ Description ^
-| itemId | unit ID |+| itemId | item ID |
 ===== Response ===== ===== Response =====
