Differences
Link to this comparison view
en:sidebar:remoteapi:apiref:item:add_log_record [29/01/2013 06:59]
zuve
en:sidebar:remoteapi:apiref:item:add_log_record [29/11/2013 13:31]
Line 1: Line 1:
-{{indexmenu_n>​6}}
-====== Logging ======
-To add log record use command **item/​add_log_record**: ​
-<code javascript>​
-svc=item/​add_log_record&​params={"​itemId":<​long>,​
- "​action":<​text>,​
- "​newValue":<​text>,​
- "​oldValue":<​text>​}
-</​code>​
-===== Parameters =====
-^ Name ^ Description ^
-| itemId | item ID |
-| action | action (see the list below) |
-| newValue | new value |
-| oldValue | ald value |
-List of available actions:
-  * **custom_msg**;​
-  * **create_unit**;​
-  * **update_name**;​
-  * **update_access**;​
-  * **update_unit_icon**;​
-  * **update_unit_pass**;​
-  * **update_unit_phone**;​
-  * **update_unit_calcflags** (update sensor calculation settings);
-  * **update_unit_milcounter** (update mileage counter value);
-  * **update_unit_bytecounter** (update GPRS traffic counter value);
-  * **update_unit_ehcounter** (update engone hours counter value);
-  * **update_unit_uid**;​
-  * **update_unit_hw** (update hardware type);
-  * **update_unit_hw_cfg** (update hardware configuration);​
-  * **update_unit_fuel_cfg** (update fuel concumption configuration);​
-  * **update_unit_trip_cfg** (update trip detection configuration);​
-  * **create_sensor**;​
-  * **update_sensor**;​
-  * **delete_sensor**;​
-  * **create_alias** (create command);
-  * **update_alias** (update command);
-  * **delete_alias** (delete command);
-  * **create_service_interval**;​
-  * **update_service_interval**;​
-  * **delete_service_interval**;​
-  * **create_custom_field**;​
-  * **update_custom_field**;​
-  * **delete_custom_field**;​
-  * **import_item_cfg**;​
-  * **import_unit_cfg**;​
-  * **export_unit_msgs**;​
-  * **import_unit_msgs**;​
-  * **delete_unit_msg**;​
-  * **delete_unit_msgs**;​
-  * **bind_unit_driver**;​
-  * **unbind_unit_driver**;​
-  * **bind_unit_trailer**;​
-  * **unbind_unit_trailer**;​
-  * **update_unit_report_cfg** (update parameters used in reports);
-  * **update_msgs_filter_cfg** (update filtration of unit position information in messages);
-  * **delete_item**;​
-  * **create_user**;​
-  * **update_hosts_mask**;​
-  * **update_user_pass**;​
-  * **update_user_flags**;​
-  * **create_user_notify**;​
-  * **delete_user_notify**;​
-  * **create_group**;​
-  * **units_group** (add/remove units into group);
-  * **update_driver_units** (update the list of auto attachable units for drivers);
-  * **update_trailer_units** (update the list of auto attachable units for trailers);
-  * **create_resource**;​
-  * **create_zone**;​
-  * **update_zone**;​
-  * **delete_zone**;​
-  * **create_poi**;​
-  * **update_poi**;​
-  * **delete_poi**;​
-  * **create_job**;​
-  * **switch_job**;​
-  * **update_job**;​
-  * **delete_job**;​
-  * **create_notify**;​
-  * **switch_notify**;​
-  * **update_notify**;​
-  * **delete_notify**;​
-  * **create_driver**;​
-  * **update_driver**;​
-  * **delete_driver**;​
-  * **create_trailer**;​
-  * **update_trailer**;​
-  * **delete_trailer**;​
-  * **create_drivers_group**;​
-  * **update_drivers_group**;​
-  * **delete_drivers_group**;​
-  * **create_trailers_group**;​
-  * **update_trailers_group**;​
-  * **delete_trailers_group**;​
-  * **create_report** (create report template);
-  * **update_report** (update report template);
-  * **delete_report** (delete report template);
-  * **import_pois**;​
-  * **import_zones**;​
-  * **create_retranslator**;​
-  * **update_retranslator**;​
-  * **units_retranslator** (add units for tertranslation);​
-  * **switch_retranslator**;​
-  * **create_route**;​
-  * **update_route_points**;​
-  * **update_route_cfg**;​
-  * **create_round**;​
-  * **update_round**;​
-  * **delete_round**;​
-  * **create_schedule**;​
-  * **update_schedule**;​
-  * **delete_schedule**;​
-  * **create_account**;​
-  * **delete_account**;​
-  * **switch_account**;​
-  * **update_dealer_rights**;​
-  * **do_payment**;​
-  * **update_account_flags**;​
-  * **update_account_min_days**;​
-  * **update_account_plan**;​
-  * **update_account_history_period**;​
-  * **update_account_subplans**;​
-  * **create_service**;​
-  * **update_service**;​
-  * **delete_service**.
-===== Response =====
-<code javascript>​
-{} /* empty object if execution successful, if not - error code */
-</​code>​
