Both sides previous revision Previous revision | |||
en:sidebar:remoteapi:apiref:format:retranslator [21/07/2014 13:21] 127.0.0.1 external edit |
en:sidebar:remoteapi:apiref:format:retranslator [29/04/2017 14:36] (current) stan [Retranslators] |
Line 5: | Line 5: | ||
This chapter describes flags that can be applied to retranslators and parts of resulting JSON which they are responsible for. If you specify several flags, then parts will be gathered into one JSON. | This chapter describes flags that can be applied to retranslators and parts of resulting JSON which they are responsible for. If you specify several flags, then parts will be gathered into one JSON. | ||
+ | :!: All flags are only used in DEC format. | ||
Retranslator flags: | Retranslator flags: | ||
- | ^ Value ^ Description | | + | ^ Value HEX ^ Value DEC ^ Description ^ |
- | | [[#General properties|0x00000001]] | base flag | | + | | [[#General properties|0x00000001]] | 1 | base flag | |
- | | [[#Custom properties|0x00000002]] | custom properties | | + | | [[#Custom properties|0x00000002]] | 2 | custom properties | |
- | | [[#Billing|0x00000004]] | billing properties | | + | | [[#Billing|0x00000004]] | 4 | billing properties | |
- | | [[#GUID|0x00000040]] | GUID | | + | | [[#GUID|0x00000040]] | 64 | GUID | |
- | | [[#Administrative fields|0x00000080]] | administrative fields | | + | | [[#Administrative fields|0x00000080]] | 128 | administrative fields | |
- | | [[#Configuration|0x00000100]] | state and configuration | | + | | [[#Configuration|0x00000100]] | 256 | state and configuration | |
- | | [[#Units|0x00000200]] | units | | + | | [[#Units|0x00000200]] | 512 | units | |
- | | 0x3FFFFFFFFFFFFFFF | set all possible flags to retranslator | | + | | 0x3FFFFFFFFFFFFFFF | 4611686018427387903 | set all possible flags to retranslator | |
===== General properties ===== | ===== General properties ===== |
