en:sidebar:remoteapi:apiref:format:messages [02/12/2019 14:45] sden [Message with data] |
en:sidebar:remoteapi:apiref:format:messages [10/02/2025 07:55] (current) zant [Video usage] |
Line 13: | Line 13: | ||
| [[#Command|0x0200]] | 512 | command | | | [[#Command|0x0200]] | 512 | command | | ||
| [[#Event|0x0600]] | 1536 | event | | | [[#Event|0x0600]] | 1536 | event | | ||
+ | | [[#Video usage|0x2000]] | 8192 | video usage | | ||
| **Resource messages** ||| | | **Resource messages** ||| | ||
| [[#Notification|0x0300]] | 768 | notification | | | [[#Notification|0x0300]] | 768 | notification | | ||
Line 67: | Line 68: | ||
| 0x20 | 32 | message contains information about driver code which come only in parameter avl_driver | | | 0x20 | 32 | message contains information about driver code which come only in parameter avl_driver | | ||
| 0x20000 | 131072 | message was corrected by lbs | | | 0x20000 | 131072 | message was corrected by lbs | | ||
+ | | 0x80000 | 524288 | message contains wi-fi position | | ||
===== SMS ===== | ===== SMS ===== | ||
Line 129: | Line 131: | ||
| 0x10 | 16 | is set in addition to flag 0x2: maintenance is registered | | | 0x10 | 16 | is set in addition to flag 0x2: maintenance is registered | | ||
| 0x20 | 32 | is set in addition to flag 0x2: registered filling | | | 0x20 | 32 | is set in addition to flag 0x2: registered filling | | ||
+ | ===== Video usage ===== | ||
+ | Flag - 0<nowiki>x</nowiki>2000(8192) | ||
+ | <code javascript> | ||
+ | "t":<uint>, /* message time (UTC) */ | ||
+ | "f":<uint>, /* flags */ | ||
+ | "tp":"xx", /* message type */ | ||
+ | "p":{ /* parameters */ | ||
+ | "cha_n":<uint>, | ||
+ | "bytes_in":<long>, | ||
+ | "action":<uint>, | ||
+ | "conn_id":<uint>, | ||
+ | "hw_id":<long> | ||
+ | </code> | ||
===== Notification ===== | ===== Notification ===== | ||
Line 199: | Line 220: | ||
- | REG;time;lon;lat;speed;course;double params;int params;text params;long params;boolean params; | + | REG;time;lon;lat;speed;course;double params;uint params;text params;long params;boolean params; |
