Get tiles of graphic layers
To get tile containing information about all enabled graphic layers, use the request:
http://{host}/avl_render/<x>_<y>_<z>/<sid>.png
:!: You can find an example of this request in the sample Messages.
Parameters
Name Description
x X-coordinate of tile
y Y-coordinate of tile
z zoom
sid session id
"adfurl":<uint> /* is specific variable to avoid browser caching with changing <uint> value in session. */
Tile coordinates are calculated according concept described in Google Custom Map Types.Zoom tiles for Webgis from 17 to z
Tile size
On default tile size is 256*256. In order to change tile size you may use render/set_locale with density param.
Response
Returns an image in PNG format.
Follow us on Facebook Gurtam Wialon Twitter Gurtam Wialon info@gurtam.com   |   Copyright © 2002-2023 Gurtam
