en:sidebar:remoteapi:apiref:core:batch [18/02/2013 09:04] zuve |
en:sidebar:remoteapi:apiref:core:batch [29/11/2013 13:31] (current) |
Line 9: | Line 9: | ||
+ | </code> | ||
+ | This command also can be called by following request: | ||
+ | <code javascript> | ||
+ | svc=core/batch¶ms={ | ||
+ | "params": [{ | ||
+ | "svc":<text>, | ||
+ | "params":{} | ||
+ | "flags":<uint>} | ||
Line 17: | Line 27: | ||
| svc | command name | | | svc | command name | | ||
| params | parameters | | | params | parameters | | ||
+ | | flags | 0 - execute all commands (by default), 1 - stop batch in case of returning error by some command | | ||
Line 30: | Line 41: | ||
+ | :!: If **"flags"** parameter has been set as **"1"** and an error has occured while executing one of the commands, then all consequent commands will return error 10. |
