Executing several commands
Several commands can be executed at one request. For this, use core/batch:
svc=core/batch&params=[
				"svc":<text>,
				"params":{}
This command also can be called by following request:
svc=core/batch&params={
			"params": [{
				"svc":<text>,
				"params":{}
			"flags":<uint>}
:!: You can find an example of this request in the sample Executing several commands at once.
Parameters
Name Description
svc command name
params parameters
flags 0 - execute all commands (by default), 1 - stop batch in case of returning error by some command
Response
	{	/* object with data if there are no errors */
	{	/* error code if an error has occurred */
		"error":<int>
:!: If “flags” parameter has been set as “1” and an error has occured while executing one of the commands, then all consequent commands will return error 10.
Follow us on Facebook Gurtam Wialon Twitter Gurtam Wialon info@gurtam.com   |   Copyright © 2002-2022 Gurtam
