en:sidebar:remoteapi:apiref:core:batch [13/02/2013 06:24] alek |
en:sidebar:remoteapi:apiref:core:batch [09/07/2013 13:09] zuve |
Line 9: | Line 9: | ||
+ | </code> | ||
+ | This command also can be called by following request: | ||
+ | <code javascript> | ||
+ | svc=core/batch¶ms={ | ||
+ | "params": [{ | ||
+ | "svc":<text>, | ||
+ | "params":{} | ||
+ | "flags":<uint>} | ||
Line 17: | Line 27: | ||
| svc | command name | | | svc | command name | | ||
| params | parameters | | | params | parameters | | ||
+ | | flags | 0 - execute all commands (by default), 1 - stop batch in case of returning error by some command | | ||
- | { | + | { /* object with data if there are no errors */ |
- | <object> /* if there are no errors */ | + | ... |
- | { | + | { /* error code if an error has occurred */ |
- | "error":<int> /* error code if an error has occurred */ | + | "error":<int> |
+ | :!: If **"flags"** parameter has been set as **"1"** and an error has occured while executing one of the commands, then all consequent commands will return error 10. |
