Differences
Link to this comparison view
en:local:remoteapi1504:codesamples:reports [20/05/2014 11:49] (current)
Line 1: Line 1:
 +{{indexmenu_n>​8}}
 +====== Reports ======
 +There are some peculiarities in working with reports. All commands from the chapter [[../​apiref/​report/​report]] except [[../​apiref/​report/​update_report|report/​update_report]] can be performed only if the session contains some results of report execution. A session can contain only one report at the same time. That's why before executing a new report, you need to clear results of the previous one by the command [[../​apiref/​report/​cleanup_result|report/​cleanup_result]].
 +//:!: Attention!//​ To launch this example at Wialon Kit, change **<​nowiki>​https://​hst-api.wialon.com</​nowiki>​** for **<​nowiki>​https://​kit-api.wialon.com</​nowiki>​** in all requests and use user name and password of your account to login to the system or name and password of demo user //**kitdemo kitdemo**//​.
 +===== Report execution =====
 +As an example let's execute a report based on the template "​_Trips,​fuel (1)". We'll choose "​Bavarian Tractor"​ as a unit and set time interval from 01.01.2013 00:00 to 20.01.2013 23:59. To do this, use the request [[../​apiref/​report/​exec_report|exec_report]]: ​
 +<​code>​
 +https://​hst-api.wialon.com/​wialon/​ajax.html?​svc=report/​exec_report&​
 + params={
 + "​reportResourceId":​163266,​
 + "​reportTemplateId":​10,​
 + "​reportObjectId":​34868,​
 + "​reportObjectSecId":​0,​
 + "​interval":​{
 + "​from":​1357938000,​
 + "​to":​1358715599,​
 + "​flags":​0
 + }&​sid=<​your_sid>​
 +</​code>​
 +Response:
 +<code javascript>​
 +    "​reportResult":​ {
 +        "​msgsRendered":​ 1,
 +        "​stats":​ [
 +            ["Move time", "​7:​09:​23"​],​
 +            ["​Trips count",​ "​120"​],​
 +            ["​Stops count",​ "​0"​],​
 +            ["​Parking time", "19 days 16:​34:​20"​],​
 +            ["​Parkings count",​ "​121"​]
 +        "​tables":​ [{
 +            "​name":​ "​unit_trips",​
 +            "​label":​ "Trips without stops",​
 +            "​flags":​ 4497,
 +            "​rows":​ 16,
 +            "​level":​ 2,
 +            "​columns":​ 16,
 +            "​header":​ ["​№",​ "​Date",​ "​Beginning",​ "​Initial location",​ "​End",​ "Final location",​ "​Driver",​ "​Duration",​ "​Engine hours",​ "​Mileage",​ "​Mileage (adjusted)",​ "Avg speed",​ "Max speed",​ "Trips count",​ "​Initial fuel level",​ "Final fuel level"​],​
 +            "​total":​ ["",​ "",​ "​2013-01-01 17:​36:​58",​ "",​ "​2013-01-20 18:​26:​50",​ "",​ "",​ "​7:​09:​23",​ "​0:​00:​00",​ "0.00 km", "0.00 km", "0 km\/​h",​ "118 km\/​h",​ "​120",​ "0 lt", "0 lt"]
 +            "​name":​ "​unit_stays",​
 +            "​label":​ "​Parkings",​
 +            "​flags":​ 272,
 +            "​rows":​ 74,
 +            "​level":​ 0,
 +            "​columns":​ 5,
 +            "​header":​ ["​Beginning",​ "​End",​ "​Duration",​ "​Location",​ "​Count"​],​
 +            "​total":​ ["​2013-01-01 00:​07:​56",​ "​2013-01-20 23:​51:​39",​ "19 days 13:​50:​40",​ "",​ "​74"​]
 +        "​attachments":​ [{
 +            "​name":​ "Speed and mileage chart",​
 +            "​type":​ "​chart",​
 +            "​datasets":​ ["​Speed,​ km\/​h",​ "​Absolute mileage",​ "​Mileage in trips"​]
 +    "​reportLayer":​ {
 +        "​name":​ "​report unit_msgs",​
 +        "​bounds":​ [53.8326976,​ 27.2796096, 53.9644416, 27.6123168],​
 +        "​units":​ [{
 +            "​id":​ 34868,
 +            "​msgs":​ {
 +                "​count":​ 6585,
 +                "​first":​ {
 +                    "​time":​ 1356984476,
 +                    "​lat":​ 53.9077377319,​
 +                    "​lon":​ 27.5011463165
 +                "​last":​ {
 +                    "​time":​ 1358711499,
 +                    "​lat":​ 53.839679718,​
 +                    "​lon":​ 27.5609111786
 +            "​mileage":​ 770003.067396,​
 +            "​max_speed":​ 118
 +    "​layerCount":​ 2
 +</​code>​
 +Conclusions that can be drawn out of the response:
 +  * report contains a table with statistics ("​stats"​ section);
 +  * report contains 2 tables - "​unit_trips"​ (Trips) and "​unit_stays"​ (Parkings);
 +  * table with trips is two-level (see "​level"​ field), has 16 columns (see "​columns"​ and "​header"​ fields) and the Total row (see "​total"​);​
 +  * report contains a chart (see "​attachments"​ section);
 +  * report contains a layer with messages (because "​msgsRendered"​ is 1);
 +  * 6585 messages were used to build this layer.
 +===== Get tables data =====
 +There are two ways to get values from report tables: ​
 +  - Using the request [[../​apiref/​report/​get_result_rows|report/​get_result_rows]]. It is suitable for most reports. However, it returns only rows of the top level. If you have a multilevel report, you need to make an additional request to get the rows of lower levels -- [[../​apiref/​report/​get_result_subrows|report/​get_result_subrows]]. ​
 +  - Using the request [[../​apiref/​report/​select_result_rows|report/​select_result_rows]]. It returns JSON that contains rows of all levels.
 +**Method 1:**
 +Let's get the first row of the table "Trips without stops",​ which has index 0 in "​tables"​ array.  ​
 +<​code>​
 +https://​hst-api.wialon.com/​wialon/​ajax.html?​svc=report/​get_result_rows&​
 + params={
 + "​tableIndex":​0,​
 + "​indexFrom":​0,​
 + "​indexTo":​0
 +</​code>​
 +Response:
 +<code javascript>​
 +    "​n":​ 0,
 +    "​i1":​ 108,
 +    "​i2":​ 214,
 +    "​t1":​ 1357047418,
 +    "​t2":​ 1357056357,
 +    "​d":​ 3,
 +    "​c":​ ["​1",​ "​2013-01-01",​ {
 +        "​t":​ "​17:​36:​58",​
 +        "​y":​ 53.9097984,
 +        "​x":​ 27.4998528
 +        "​t":​ "​Beruta st., Minsk",​
 +        "​x":​ 27.4998528
 +        "​t":​ "​20:​05:​57",​
 +        "​y":​ 53.8847872,
 +        "​x":​ 27.5675072
 +        "​t":​ "​Mayakovskogo st., Minsk",​
 +        "​x":​ 27.5675072
 +    }, "",​ "​0:​11:​15",​ "​0:​00:​00",​ "0.00 km", "0.00 km", "0 km\/​h",​ {
 +        "​t":​ "72 km\/​h",​
 +        "​y":​ 53.9070656,
 +        "​x":​ 27.5216608
 +    }, "​3",​ "0 lt", "0 lt"]
 +</​code>​
 +Number 3 in the parameter //d// tells us that the current row contains 3 subrows. To get them, make the request:
 +<​code>​
 +https://​hst-api.wialon.com/​wialon/​ajax.html?​svc=report/​get_result_subrows&​
 + params={
 + "​rowIndex":​0
 +</​code>​
 +Response:
 +<code javascript>​
 +    "​n":​ 0,
 +    "​i1":​ 108,
 +    "​i2":​ 118,
 +    "​t2":​ 1357047581,
 +    "​d":​ 0,
 +    "​c":​ ["​1.1",​ "",​ {
 +        "​x":​ 27.4998528
 +        "​x":​ 27.4998528
 +        "​t":​ "​17:​39:​41",​
 +        "​y":​ 53.9152448,
 +        "​x":​ 27.4865568
 +        "​t":​ "​Matusevicha st., Minsk",​
 +        "​x":​ 27.4865568
 +    }, "",​ "​0:​02:​43",​ "​0:​00:​00",​ "0.00 km", "0.00 km", "0 km\/​h",​ {
 +        "​t":​ "34 km\/​h",​
 +        "​y":​ 53.910112,
 +        "​x":​ 27.495648
 +    }, "​1",​ "0 lt", "0 lt"]
 +    "​n":​ 1,
 +    "​i1":​ 151,
 +    "​i2":​ 169,
 +    "​t1":​ 1357053985,
 +    "​t2":​ 1357054222,
 +    "​d":​ 0,
 +    "​c":​ ["​1.2",​ "",​ {
 +        "​t":​ "​19:​26:​25",​
 +        "​y":​ 53.9205888,
 +        "​x":​ 27.492064
 +        "​t":​ "​Danily Serdicha st., 68, Minsk",​
 +        "​x":​ 27.492064
 +        "​t":​ "​19:​30:​22",​
 +        "​y":​ 53.9094592,
 +        "​x":​ 27.4950912
 +        "​t":​ "​Pritytskogo st., Ratomka",​
 +        "​x":​ 27.4950912
 +    }, "",​ "​0:​03:​57",​ "​0:​00:​00",​ "0.00 km", "0.00 km", "0 km\/​h",​ {
 +        "​t":​ "41 km\/​h",​
 +        "​y":​ 53.9177472,
 +        "​x":​ 27.4873152
 +    "​n":​ 2,
 +    "​i1":​ 200,
 +    "​i2":​ 214,
 +    "​t1":​ 1357056082,
 +    "​d":​ 0,
 +    "​c":​ ["​1.3",​ "",​ {
 +        "​t":​ "​20:​01:​22",​
 +        "​y":​ 53.8974912,
 +        "​x":​ 27.5369984
 +        "​t":​ "Klary Tsetkin st., Minsk",​
 +        "​x":​ 27.5369984
 +        "​x":​ 27.5675072
 +        "​x":​ 27.5675072
 +    }, "",​ "​0:​04:​35",​ "​0:​00:​00",​ "0.00 km", "0.00 km", "0 km\/​h",​ {
 +        "​t":​ "62 km\/​h",​
 +        "​y":​ 53.8868928,
 +        "​x":​ 27.5656
 +</​code>​
 +**Method 2:**
 +After report execution, we know that maximal nesting level of the table "Trips without stops" is 2. Now we will make a request which will return the first row with its subrows which nesting level is 2 or less:
 +<​code>​
 +https://​hst-api.wialon.com/​wialon/​ajax.html?​svc=report/​select_result_rows&​
 + params={
 + "​config":​{
 + "​type":"​range",​
 + "​data":​{
 + "​from":​0,​
 + "​to":​0,​
 + "​level":​2
 +</​code>​
 +Response:
 +<code javascript>​
 +    "​n":​ 0,
 +    "​i1":​ 108,
 +    "​i2":​ 214,
 +    "​d":​ 3,
 +        "​x":​ 27.4998528
 +        "​x":​ 27.4998528
 +        "​x":​ 27.5675072
 +        "​x":​ 27.5675072
 +        "​x":​ 27.5216608
 +    }, "​3",​ "0 lt", "0 lt"],
 +    "​r":​ [{
 +        "​n":​ 0,
 +        "​i1":​ 108,
 +        "​i2":​ 118,
 +        "​d":​ 0,
 +            "​x":​ 27.4998528
 +            "​x":​ 27.4998528
 +            "​x":​ 27.4865568
 +            "​x":​ 27.4865568
 +            "​y":​ 53.910112,
 +            "​x":​ 27.495648
 +        "​n":​ 1,
 +        "​i1":​ 151,
 +        "​i2":​ 169,
 +        "​d":​ 0,
 +            "​x":​ 27.492064
 +            "​x":​ 27.492064
 +            "​x":​ 27.4950912
 +            "​x":​ 27.4950912
 +            "​x":​ 27.4873152
 +        "​n":​ 2,
 +        "​i1":​ 200,
 +        "​i2":​ 214,
 +        "​d":​ 0,
 +            "​x":​ 27.5369984
 +            "​x":​ 27.5369984
 +            "​x":​ 27.5675072
 +            "​x":​ 27.5675072
 +            "​x":​ 27.5656
 +</​code>​
 +===== Getting graphic data =====
 +As was told before, a layer with trips and parkings was generated for the report. We can get the image of this layer (combined with map) using the request [[../​apiref/​report/​get_result_map|get_result_map]]:​
 +<​code>​
 +https://​hst-api.wialon.com/​wialon/​ajax.html?​svc=report/​get_result_map&​
 + params={
 + "​width":​600,​
 + "​height":​600
 +</​code>​
 +Response:
 +{{ /​remote_ex/​map.png?​nolink }}
 +Also there is "Speed and mileage chart" in the report. You can get its image using the request [[../​apiref/​report/​get_result_chart|get_result_chart]]. To place a chart name above the chart, set the flag 0×01, and to place a legend under the chart, set the flag 0x200.
 +<​code>​
 +https://​hst-api.wialon.com/​wialon/​ajax.html?​svc=report/​get_result_chart&​
 + params={
 + "​attachmentIndex":​0,​
 + "​action":​0,​
 + "​width":​600,​
 + "​height":​300,​
 + "​autoScaleY":​0,​
 + "​pixelFrom":​0,​
 + "​pixelTo":​300,​
 + "​flags":​513
 +</​code>​
 +Response:
 +{{ /​remote_ex/​chart_en.png?​nolink }}
