Differences
en:local:remoteapi1504:codesamples:login [20/05/2014 11:49] (current) |
| {{indexmenu_n>1}} |
| ====== Login/logout ====== |
| To execute any command in Wialon, you need authorize and get session ID. |
| //:!: Attention!// To launch this example at Wialon Kit, change **<nowiki>https://hst-api.wialon.com</nowiki>** for **<nowiki>https://kit-api.wialon.com</nowiki>** in all requests and use user name and password of your account to login to the system or name and password of demo user //**kitdemo kitdemo**//. |
| ===== Login ===== |
| To get authorized, make the request [[../apiref/core/login|core/login]]. In current example, we use demo login and password of **<nowiki>https://hst-api.wialon.com</nowiki>**. |
| <code> |
| https://hst-api.wialon.com/wialon/ajax.html?svc=core/login& |
| params={ |
| "user":"wialon_test", |
| "password":"test" |
| </code> |
| Response: |
| <code javascript> |
| "host": "212.98.173.107", |
| "eid": "d1cb60897768780f846df7ab2400eb5f", |
| "tm": 1358415984, |
| "user": { |
| "nm": "wialon_test", |
| "cls": 1, |
| "id": 50935, |
| "prp": { |
| "addr_provider": "map_visicom", |
| "cfmt": "0", |
| "city": "Mexico", |
| "dst": "-1", |
| "fpnl": "monitoring", |
| "language": "ru", |
| "show_log": "0", |
| "tz": "134232128", |
| "user_settings_hotkeys": "1", |
| "crt": 0, |
| "bact": 50936, |
| "fl": 6, |
| "hm": "", |
| "uacl": 2097795 |
| "classes": { |
| "avl_hw": 4, |
| "avl_resource": 3, |
| "avl_retranslator": 7, |
| "avl_route": 6, |
| "avl_unit": 2, |
| "avl_unit_group": 5, |
| "user": 1 |
| </code> |
| For further operations, we need session ID which is specified in the field **eid**. In our case it is **d1cb60897768780f846df7ab2400eb5f**. |
| ===== Logout ===== |
| To stop working with Wialon and logout from the system, deactivate the session making the following request: |
| <code> |
| https://hst-api.wialon.com/wialon/ajax.html?svc=core/logout¶ms={}&sid=d1cb60897768780f846df7ab2400eb5f |
| </code> |
| Response: |
| <code javascript> |
| "error":0 |
| </code> |
| Such result tells us that the exit was successful. |
| Parameters of this request as well as the returned value are described in the chapter [[../apiref/core/logout]]. |
