Differences
Link to this comparison view
en:local:javaapi:codesamples:update_datafalags [20/05/2014 11:49]
en:local:javaapi:codesamples:update_datafalags [20/05/2014 11:49] (current)
Line 1: Line 1:
 +{{indexmenu_n>​3}}
 +====== Item events management ======
 +Management of system items and events allows to choose types of events to be received, get these events and process them.
 +//:!: Attention!//​ To launch this example at Wialon Kit, change **<​nowiki>​http://​hst-api.wialon.com</​nowiki>​** for **<​nowiki>​http://​kit-api.wialon.com</​nowiki>​** in all requests and use user name and password of your account to login to the system or name and password of demo user //**kitdemo kitdemo**//​.
 +<code java>
 +package com.wialon.java.test;​
 +import com.wialon.core.Errors;​
 +import com.wialon.core.EventHandler;​
 +import com.wialon.core.EventProvider;​
 +import com.wialon.core.Session;​
 +import com.wialon.extra.UpdateSpec;​
 +import com.wialon.item.Item;​
 +import com.wialon.item.Unit;​
 +import com.wialon.remote.handlers.ResponseHandler;​
 +import java.io.IOException;​
 +import java.util.Collection;​
 +public class EventsManagementExample implements Runnable {
 +    private Session session;
 +    // Login to server
 +    private void login(){
 +        // initialize Wialon session
 +        session.initSession("​http://​hst-api.wialon.com"​);​
 +        // trying login
 +        session.login("​wialon_test",​ "​test",​ new ResponseHandler() {
 +            @Override
 +            public void onSuccess(String response) {
 +                super.onSuccess(response);​
 +                // login succeed
 +                System.out.println(String.format("​Logged successfully. User name is %s", session.getCurrUser().getName()));​
 +                //call update data flags
 +                updateDataFlags();​
 +            @Override
 +            public void onFailure(int errorCode, Throwable throwableError) {
 +                super.onFailure(errorCode,​ throwableError);​
 +                // login failed, print error
 +                System.out.println(Errors.getErrorText(errorCode));​
 +    private void updateDataFlags(){
 +        //Create new update specification
 +        UpdateSpec updateSpec=new UpdateSpec();​
 +        //Set update mode to add specified flags
 +        updateSpec.setMode(1);​
 +        //Set update type by type
 +        updateSpec.setType("​type"​);​
 +        //Set update data to units
 +        updateSpec.setData(Item.ItemType.avl_unit);​
 +        //Set update data flags
 +        updateSpec.setFlags(Item.dataFlag.base.getValue()| Unit.dataFlag.lastMessage.getValue());​
 +        //Send update by created update specification
 +        session.updateDataFlags(new UpdateSpec[]{updateSpec},​ new ResponseHandler() {
 +            @Override
 +                // Update succeed
 +                System.out.println("​Update data flags is successful"​);​
 +                bindEventsHandler();​
 +            @Override
 +                // update data flags failed, print error
 +                logout();
 +    private void bindEventsHandler(){
 +        //Get items from session
 +        Collection<​Item>​ sessionItems=session.getItems();​
 +        //Create events handler
 +        EventsHandlerExample eventsHandlerExample=new EventsHandlerExample();​
 +        //Add handler to session
 +        session.addListener(eventsHandlerExample,​ EventProvider.events.All);​
 +        if (sessionItems!=null && sessionItems.size()>​0) {
 +            System.out.println(String.format("​%d items added to Session\r\nStart binding event listeners to items",​ sessionItems.size()));​
 +            //Add handler to items
 +            for (Item item : sessionItems)
 +                item.addListener(eventsHandlerExample,​ EventProvider.events.All);​
 +            System.out.println("​Event listeners successfully bound to items\r\nPress enter to logout and exit"​);​
 +        //Wait for press enter key
 +        try {
 +            System.in.read();​
 +            logout();
 +        } catch (IOException e) {
 +            e.printStackTrace();​
 +    // Logout
 +    private void logout(){
 +        session.logout(new ResponseHandler() {
 +            @Override
 +                // logout succeed
 +                System.out.println("​Logout successfully"​);​
 +                System.exit(0);​
 +            @Override
 +                // logout failed, print error
 +                System.exit(0);​
 +    //​EventHandler witch listen bound event types
 +    private class EventsHandlerExample implements EventHandler{
 +        @Override
 +        public void onEvent(Enum event, Object object, Object oldData, Object newData) {
 +            String objectValue= object==null ? "​null"​ : object.toString();​
 +            String oldDataValue= oldData==null ? "​null"​ : oldData.toString();​
 +            String newDataValue= newData==null ? "​null"​ : newData.toString();​
 +            System.out.println(String.format("​Fired event with type %s, object is %s, oldData is %s, newData is %s", event, objectValue,​ oldDataValue,​ newDataValue));​
 +    @Override
 +    public void run() {
 +        // get instance of current Session
 +        session=Session.getInstance();​
 +        login();
 +    public static void main(String[] args){
 +        new Thread(new EventsManagementExample()).start();​
 +</​code>​
