Differences
Link to this comparison view
en:local:javaapi:codesamples:search [20/05/2014 11:49]
en:local:javaapi:codesamples:search [20/05/2014 11:49] (current)
Line 1: Line 1:
 +{{indexmenu_n>​2}}
 +====== Unit search ======
 +This example shows how you can get all units available to current user.
 +//:!: Attention!//​ To launch this example at Wialon Kit, change **<​nowiki>​http://​hst-api.wialon.com</​nowiki>​** for **<​nowiki>​http://​kit-api.wialon.com</​nowiki>​** in all requests and use user name and password of your account to login to the system or name and password of demo user //**kitdemo kitdemo**//​.
 +<code java>
 +package com.wialon.java.test;​
 +import com.wialon.core.Errors;​
 +import com.wialon.core.Session;​
 +import com.wialon.extra.SearchSpec;​
 +import com.wialon.item.Item;​
 +import com.wialon.remote.handlers.ResponseHandler;​
 +import com.wialon.remote.handlers.SearchResponseHandler;​
 +public class UnitsSearchExample implements Runnable {
 +    private Session session;
 +    // Login to server
 +    private void login(){
 +        // initialize Wialon session
 +        session.initSession("​http://​hst-api.wialon.com"​);​
 +        // trying login
 +        session.login("​wialon_test",​ "​test",​ new ResponseHandler() {
 +            @Override
 +            public void onSuccess(String response) {
 +                super.onSuccess(response);​
 +                // login succeed
 +                System.out.println(String.format("​Logged successfully. User name is %s", session.getCurrUser().getName()));​
 +                //call search units
 +                searchUnits();​
 +            @Override
 +            public void onFailure(int errorCode, Throwable throwableError) {
 +                super.onFailure(errorCode,​ throwableError);​
 +                // login failed, print error
 +                System.out.println(Errors.getErrorText(errorCode));​
 +    private void searchUnits(){
 +        //Create new search specification
 +        SearchSpec searchSpec=new SearchSpec();​
 +        //Set items type to search avl_units
 +        searchSpec.setItemsType(Item.ItemType.avl_unit);​
 +        //Set property name to search
 +        searchSpec.setPropName("​sys_name"​);​
 +        //Set property value mask to search all units
 +        searchSpec.setPropValueMask("​*"​);​
 +        //Set sort type by units name
 +        searchSpec.setSortType("​sys_name"​);​
 +        //Send search by created search specification with items base data flag and from 0 to maximum number
 +        session.searchItems(searchSpec,​ 1, Item.dataFlag.base.getValue(),​ 0, Integer.MAX_VALUE,​ new SearchResponseHandler() {
 +            @Override
 +            public void onSuccessSearch(Item... items) {
 +                super.onSuccessSearch(items);​
 +                // Search succeed
 +                System.out.println("​Search items is successful"​);​
 +                printUnitsNames(items);​
 +                logout();
 +            @Override
 +                // search item failed, print error
 +                logout();
 +    private void printUnitsNames(Item... items){
 +        if (items!=null && items.length>​0) {
 +            System.out.println(String.format("​%d units found\r\nPrinting their names...",​ items.length));​
 +            //Print items names
 +            for (Item item : items)
 +                System.out.println(String.format("​\t%s",​ item.getName()));​
 +    // Logout
 +    private void logout(){
 +        session.logout(new ResponseHandler() {
 +            @Override
 +                // logout succeed
 +                System.out.println("​Logout successfully"​);​
 +                System.exit(0);​
 +            @Override
 +                // logout failed, print error
 +                System.exit(0);​
 +    @Override
 +    public void run() {
 +        // get instance of current Session
 +        session=Session.getInstance();​
 +        login();
 +    public static void main(String[] args){
 +        new Thread(new UnitsSearchExample()).start();​
 +</​code>​
