Geofences: create, edit, delete
To create, edit or delete geofences, use the command resource/update_zone:
svc=resource/update_zone&params={"itemId":<long>,
				 "id":<long>,
				 "callMode":<text>,
				 "n":<text>,
				 "t":<int>,
				 "w":<int>,
				 "p":[{
					"x":<double>,
					"y":<double>,
					"r":<int>
				 "d":{
					"addr":<unit>,
					"rideBegin":<uint>,
					"rideEnd":<uint>,
					"color":<uint>
Parameters
Name Description
itemId resource ID
id geofence ID
callMode action: create, update, delete
Parameters required only for create and update:
n geofence name
t type: 1 - line, 2 - polygon, 3 - circle
w line thickness or circle radius
p array of geofence points
x longitude
y latitude
r radius
d description
addr address source: 0 - no, 1 - yes
rideBegin ride beginning: 0 - no, 1 - yes
rideEnd ride end: 0 - no, 1 - yes
color color (ARGB)
Response
On create and edit:
	<long>,		/* geofence ID */
		"n":<text>,	/* name */
		"id":<long>,	/* ID */
		"t":<int>,	/* type: 1 - line, 2 - polygon, 3 - circle */
		"d":<int>	/* line thickness or circle radius */
		"dr":{		/* description */
			"addr":<uint>,		/* address source: 0 - no, 1 - yes */
			"rideBegin":<uint>,	/* ride beginning: 0 - no, 1 - yes */
			"rideEnd":<uint>,	/* ride end: 0 - no, 1 - yes */
			"color":<uint>,		/* color (ARGB) */
On delete:
	null
Errors
Code Value
1 invalid session
2 invalid service name
3 invalid result
4 - invalid format or value of parameters
- error updating geofence
6 - geofence with current ID doesn't exist
- error deleting geofence
7 - access denied
- service is not activated
