Table of Contents
Operate As
To login to the system on behalf of other user, you need to execute the command core/duplicate:
svc=core/duplicate&params={"operateAs":<text>,
			   "continueCurrentSession":<bool>}
It duplicates the active session.
Parameters
Name Description
operateAs name of a user you want to operate as (must be empty if you want to operate as the main user)
continueCurrentSession defines whether to continue the previous session (false by default, if true - both sid's remain valid)
Response
Response format is be the same as in the command login.
Follow us on Facebook Gurtam Wialon Twitter Gurtam Wialon info@gurtam.com   |   Copyright © 2002-2023 Gurtam
