Update drive rank settings
svc=unit/update_drive_rank_settings&params={"itemId":<long>,
                                            "driveRank":
                                                    "acceleration":[
                                                             "flags":<uint>,
                                                             "min_value":<double>,
                                                             "max_value":<double>,
                                                             "min_speed":<uint>,
                                                             "max_speed":<uint>,
                                                             "min_duration":<uint>,
                                                             "max_duration":<uint>,
                                                             "validator_id":<long>,
                                                             "name":<text>,
                                                             "penalties":<uint>
                                                    "brake":[
                                                             "flags":<uint>,
                                                             "min_speed":<uint>,
                                                             "max_speed":<uint>,
                                                             "name":<text>,
                                                             "penalties":<uint>
                                                    "turn":[
                                                             "flags":<uint>,
                                                             "min_speed":<uint>,
                                                             "max_speed":<uint>,
                                                             "name":<text>,
                                                             "penalties":<uint>
                                                    "sensor":[
                                                             "flags":<uint>,
                                                             "min_speed":<uint>,
                                                             "max_speed":<uint>,
                                                             "sensor_id":<long>,
                                                             "name":<text>,
                                                             "penalties":<uint>
                                                    "speeding":[
                                                             "flags":<uint>,
                                                             "min_speed":<uint>,
                                                             "max_speed":<uint>,
                                                             "name":<text>,
                                                             "penalties":<uint>
                                                    "harsh":[
                                                             "flags":<uint>,
                                                             "min_speed":<uint>,
                                                             "max_speed":<uint>,
                                                             "name":<text>,
                                                             "penalties":<uint>
                                                    "global":
							     "accel_mode":<uint>
Parameters
It is optional to set evaluation criteria. DriveRank may contain empty object {}.
Params Description
accel_mode Penalties calculating method
0 - combined,
1 - by speed in messages,
2 - by по accelerometer values
itemId item ID
driveRank drive rank criteria parameters object
Evaluation criteria
acceleration acceleration
brake brake
turn turn
sensor sensor
speeding speeding
harsh harsh driving
global global criteria
Criteria settings
flags flags:
1 - penalties averaging by time;
2 - by mileage;
4 - validator=multiplier;
8 - skip missing values
min_value min value
max_value max value (excluded)
min_speed min speed
max_speed max speed (excluded)
min_duration min duration
max_duration max duration (included)
validator_id validator sensor id
sensor_id sensor id (for sensor evaluation criterion only)
name any criterion name
penalties penalties
accel_mode calculate acceleration by:
0 - GPS+accelerometer;​
1 - GPS;
2 - accelerometer.
Response
Returns empty object {} if settings saved successfully.
