If you want to get files from default or custom libraries please use file/library command:
svc=file/library¶ms={"type":<text>, "flags":<uint>}
| Name | Description |
| type | library name; default values: unit, group, poi |
| flags | 0 - list files from default library only (valid are default type values); 1 - list files from all available hierarchy libraries recur- sively (this account, parent, parent's parent etc) |
1. Create “library” directory in the account public file storage (<account_id>/1/library);
2. Put custom library in “library” folder (put assumed “cust_lib” library – <account_id>/1/library/cust_lib);
3. To list library content we type library name as type value (so we will search type:'cust_lib' from the example above).
{ "<account_id>": [ /* account id, 0 - default library */ { "n":<text>, /* file name */ "s":<uint>, /* file size (bytes) */ "ct":<uint>, /* file creation time, UNIX-time */ "mt":<uint> /* file last modification time, UNIX-time */ }, ... ], ... /* other account ids (if any) */ }
