en:sidebar:remoteapi:apiref:core:use_auth_hash [21/05/2015 15:20] mast |
en:sidebar:remoteapi:apiref:core:use_auth_hash [06/04/2016 13:38] (current) stan |
Line 6: | Line 6: | ||
svc=core/use_auth_hash¶ms={"authHash":<text>, | svc=core/use_auth_hash¶ms={"authHash":<text>, | ||
- | "operateAs":<text>} | + | "operateAs":<text>, |
+ | "checkService":<text>} | ||
Line 13: | Line 14: | ||
| authHash | authorization hash that you can get using [[create_auth_hash|core/create_auth_hash]] request | | | authHash | authorization hash that you can get using [[create_auth_hash|core/create_auth_hash]] request | | ||
| operateAs | subuser name to log in | | | operateAs | subuser name to log in | | ||
+ | | checkService | you can check on [[../account/get_account_data#spisok_servisov | service]] | | ||
Response format is be the same as in the command [[login|login]]. | Response format is be the same as in the command [[login|login]]. |
