Both sides previous revision Previous revision | Next revision Both sides next revision | ||
en:sidebar:remoteapi:apiref:core:use_auth_hash [29/11/2013 12:31] 127.0.0.1 external edit |
en:sidebar:remoteapi:apiref:core:use_auth_hash [21/05/2015 15:20] mast |
Line 5: | Line 5: | ||
- | svc=core/use_auth_hash¶ms={"authHash":<text>} | + | svc=core/use_auth_hash¶ms={"authHash":<text>, |
+ | "operateAs":<text>} | ||
Line 11: | Line 12: | ||
| authHash | authorization hash that you can get using [[create_auth_hash|core/create_auth_hash]] request | | | authHash | authorization hash that you can get using [[create_auth_hash|core/create_auth_hash]] request | | ||
+ | | operateAs | subuser name to log in | | ||
Response format is be the same as in the command [[login|login]]. | Response format is be the same as in the command [[login|login]]. |
