en:sidebar:remoteapi:apiref:core:update_data_flags [08/12/2014 07:25] mast |
en:sidebar:remoteapi:apiref:core:update_data_flags [15/05/2018 15:00] stan [Parameters] |
Line 23: | Line 23: | ||
| type | method of transmitting items to the session (see the list below) | | | type | method of transmitting items to the session (see the list below) | | ||
| data | data (depends on the value of the "type" parameter) | | | data | data (depends on the value of the "type" parameter) | | ||
- | | flags | flags that define what part of item data will be added to the session (data formats of all item types and their flags are described in the chapter [[../format/format|]])| | + | | flags | flags that define what part of item data will be added to the session (data for-\\ mats of all item types and their flags are described in the chapter [[../format/format|]])| |
| mode | flags application mode (see the list below)| | | mode | flags application mode (see the list below)| | ||
| max_items | param is available when __type='type'__, defines max quantity of subscribed items| | | max_items | param is available when __type='type'__, defines max quantity of subscribed items| | ||
Line 30: | Line 30: | ||
* **id** -- by ID (if such a method is selected, you indicate item ID in the **data** parameter); | * **id** -- by ID (if such a method is selected, you indicate item ID in the **data** parameter); | ||
* **type** -- by type (if such a method is selected, you indicate item type in the **data** parameter - see [[search_items|]]); | * **type** -- by type (if such a method is selected, you indicate item type in the **data** parameter - see [[search_items|]]); | ||
- | * **col** -- by list of IDs (if such a method is selected, you write an array of item IDs in the **data** parameter). | + | * **col** -- by list of IDs (if such a method is selected, you write an array of item IDs in the **data** parameter), |
+ | * **access** -- subscribe to creating/deleting, receiving/denying access rights to items events, parameter ** data **: 1 enable, 0 - disable. | ||
Flags application mode: | Flags application mode: |
