Both sides previous revision Previous revision | Next revision Both sides next revision | ||
en:sidebar:remoteapi:apiref:core:search_items [06/12/2019 14:04] chdi [Parameters] |
en:sidebar:remoteapi:apiref:core:search_items [03/01/2020 12:52] chdi [Parameters] |
Line 76: | Line 76: | ||
* **rel_adminfield_name** - the name of unit admin field; | * **rel_adminfield_name** - the name of unit admin field; | ||
* **rel_adminfield_value** - the value of unit admin field; | * **rel_adminfield_value** - the value of unit admin field; | ||
- | * **rel_customfield_name** - the name and value of unit custom field, separated by ":"; | + | * **rel_customfield_name_value** - the name and value of unit custom field, separated by ":"; |
- | * **rel_profilefield_name** - the name and value of unit profile field, separated by ":"; | + | * **rel_profilefield_name_value** - the name and value of unit profile field, separated by ":"; |
* **rel_adminfield_name** - the name and value of unit admin field, separated by ":". | * **rel_adminfield_name** - the name and value of unit admin field, separated by ":". | ||
Line 93: | Line 93: | ||
* **profilefield** -- profile fields; | * **profilefield** -- profile fields; | ||
* **adminfield** -- administrative fields. | * **adminfield** -- administrative fields. | ||
+ | * **rel_profilefield_name_value** -- profile fields with their values | ||
:!: If you need to perform a search in subitems, set the value //propitemname// for the parameter "**propType**". Then, other parameters can have any of these values: | :!: If you need to perform a search in subitems, set the value //propitemname// for the parameter "**propType**". Then, other parameters can have any of these values: |
