en:sidebar:remoteapi:apiref:core:search_items [11/12/2017 16:54] stan [Parameters] |
en:sidebar:remoteapi:apiref:core:search_items [03/01/2020 12:52] chdi [Parameters] |
Line 53: | Line 53: | ||
* **sys_billing_account_guid** -- account ID; | * **sys_billing_account_guid** -- account ID; | ||
* **rel_billing_account_name** -- account name; | * **rel_billing_account_name** -- account name; | ||
+ | * **rel_billing_parent_account_name** -- parent account name; | ||
* **rel_billing_plan_name** -- billing plan name; | * **rel_billing_plan_name** -- billing plan name; | ||
* **sys_comm_state** -- hardware state (1 - enabled, 0 - disabled); | * **sys_comm_state** -- hardware state (1 - enabled, 0 - disabled); | ||
Line 60: | Line 61: | ||
* **sys_account_days** -- account days; | * **sys_account_days** -- account days; | ||
* **sys_account_enable_parent** -- dealer rights (1 - on, 0 - off); | * **sys_account_enable_parent** -- dealer rights (1 - on, 0 - off); | ||
- | * **sys_account_disabled** -- account blocked (1 - yes, 0 - no); | + | * **sys_account_disabled** -- account blocked (1 - blocked); |
* **rel_account_disabled_mod_time** -- last modification time for ''sys_account_disabled'', UNIX-time; | * **rel_account_disabled_mod_time** -- last modification time for ''sys_account_disabled'', UNIX-time; | ||
* **rel_account_units_usage** -- number of units used in account; | * **rel_account_units_usage** -- number of units used in account; | ||
Line 75: | Line 76: | ||
* **rel_adminfield_name** - the name of unit admin field; | * **rel_adminfield_name** - the name of unit admin field; | ||
* **rel_adminfield_value** - the value of unit admin field; | * **rel_adminfield_value** - the value of unit admin field; | ||
- | * **rel_customfield_name** - the name and value of unit custom field, separated by ":"; | + | * **rel_customfield_name_value** - the name and value of unit custom field, separated by ":"; |
- | * **rel_profilefield_name** - the name and value of unit profile field, separated by ":"; | + | * **rel_profilefield_name_value** - the name and value of unit profile field, separated by ":"; |
* **rel_adminfield_name** - the name and value of unit admin field, separated by ":". | * **rel_adminfield_name** - the name and value of unit admin field, separated by ":". | ||
Line 92: | Line 93: | ||
* **profilefield** -- profile fields; | * **profilefield** -- profile fields; | ||
* **adminfield** -- administrative fields. | * **adminfield** -- administrative fields. | ||
+ | * **rel_profilefield_name_value** -- profile fields with their values | ||
:!: If you need to perform a search in subitems, set the value //propitemname// for the parameter "**propType**". Then, other parameters can have any of these values: | :!: If you need to perform a search in subitems, set the value //propitemname// for the parameter "**propType**". Then, other parameters can have any of these values: | ||
Line 118: | Line 120: | ||
<!-- resources--> | <!-- resources--> | ||
<tr class="row1"> | <tr class="row1"> | ||
- | <td class="col0" rowspan=9 align="center"> <strong>avl_resource</strong> </td><td class="col1"> <i>drivers </i></td> | + | <td class="col0" rowspan=10 align="center"> <strong>avl_resource</strong> </td><td class="col1"> <i>drivers </i></td> |
</tr> | </tr> | ||
Line 145: | Line 147: | ||
<td class="col1"> <i>reporttemplates</i> </td> | <td class="col1"> <i>reporttemplates</i> </td> | ||
</tr> | </tr> | ||
+ | </tr> | ||
+ | <tr class="row1"> | ||
+ | <td class="col1"> <i>orders</i> </td> | ||
+ | </tr> | ||
<!-- routes--> | <!-- routes--> |
