en:sidebar:remoteapi:apiref:core:search_item [25/01/2013 09:06] zuve |
en:sidebar:remoteapi:apiref:core:search_item [29/11/2013 12:31] 127.0.0.1 external edit |
Line 2: | Line 2: | ||
====== Search item by ID ====== | ====== Search item by ID ====== | ||
- | To find item with certain ID use command **core/search_item**: | + | To find an item with certain ID, use the command **core/search_item**: |
svc=core/search_item¶ms={"id":<long>, | svc=core/search_item¶ms={"id":<long>, | ||
Line 8: | Line 8: | ||
- | :!: The example with this request you can find in chapter [[../../codesamples/search]]. | + | :!: You can find an example of this request in the sample [[../../codesamples/search|]]. |
| id | item ID | | | id | item ID | | ||
- | | flags | data flags for response (Value of this parameter depends on item type you want to find. Data formats of all elements and their flags are describedin chapter [[../format/format]].)| | + | | flags | data flags for the response (the value of this parameter depends on item type; data formats of all item types and their flags are described in the chapter [[../format/format|]])| |
Line 24: | Line 24: | ||
- | Format of field "item" depends on type of fount item. All formats are enumerated in chapter [[../format/format]]. | + | The format of "item" depends on item type. All formats are described in the chapter [[../format/format|]]. |
