en:sidebar:remoteapi:apiref:core:duplicate [13/02/2013 06:30] alek |
en:sidebar:remoteapi:apiref:core:duplicate [03/06/2021 11:27] (current) chdi [Response] |
Line 7: | Line 7: | ||
"continueCurrentSession":<bool>} | "continueCurrentSession":<bool>} | ||
- | It duplicates the active session. Both sessions should be initiated from the same IP. | + | It duplicates the active session. |
Line 15: | Line 15: | ||
- | Response format is be the same as in the command [[login|login]]. | + | Response format is be the same as in the command [[en:sidebar:remoteapi:apiref:token:login]] |
