en:sidebar:remoteapi:apiref:core:duplicate [02/04/2013 09:19] zuve |
en:sidebar:remoteapi:apiref:core:duplicate [03/06/2021 11:27] chdi [Response] |
Line 5: | Line 5: | ||
svc=core/duplicate¶ms={"operateAs":<text>, | svc=core/duplicate¶ms={"operateAs":<text>, | ||
- | "continueCurrentSession":<bool>, | + | "continueCurrentSession":<bool>} |
- | "clientIp":<text>} | + | |
- | It duplicates the active session. Both sessions should be initiated from the same IP. | + | It duplicates the active session. |
Line 16: | Line 15: | ||
- | Response format is be the same as in the command [[login|login]]. | + | Response format is be the same as in the command [[en:sidebar:remoteapi:apiref:token:login]] |
