en:sidebar:remoteapi:apiref:core:create_unit_group [24/01/2013 14:16] zuve |
en:sidebar:remoteapi:apiref:core:create_unit_group [12/02/2013 11:45] alek |
Line 2: | Line 2: | ||
====== Create unit group ====== | ====== Create unit group ====== | ||
- | To create a new unit group use command **core/create_unit_group**: | + | To create a new unit group, use the command **core/create_unit_group**: |
svc=core/create_unit_group¶ms={"creatorId":<long>, | svc=core/create_unit_group¶ms={"creatorId":<long>, | ||
Line 11: | Line 11: | ||
- | | creatorId | ID of user, who will be assigned as creator for new user | | + | | creatorId | ID of a user who will be assigned a creator for a new unit group | |
| name | new unit group name (at least 4 characters) | | | name | new unit group name (at least 4 characters) | | ||
- | | dataFlags | data flags for response (see [[../format/group|Data format: Unit group]])| | + | | dataFlags | data flags for the response (see [[../format/group|Data format: Unit group]])| |
Line 24: | Line 24: | ||
- | Format of field "item" you can see in chapter [[../format/group|Data format: Unit group]]. | + | You can find the format of “item” in the chapter [[../format/group|Data format: Unit group]]. |
