en:sidebar:remoteapi:apiref:core:create_unit [12/02/2013 11:44] alek |
en:sidebar:remoteapi:apiref:core:create_unit [07/04/2014 08:27] 127.0.0.1 external edit |
Line 25: | Line 25: | ||
- | "flags":<unit> /* applied data flags */ | + | "flags":<uint> /* applied data flags */ |
You can find the format of “item” in the chapter [[../format/unit|Data format: Units]]. | You can find the format of “item” in the chapter [[../format/unit|Data format: Units]]. |
