Differences
Both sides previous revision
Previous revision
Next revision
Previous revision
en:sidebar:remoteapi:apiref:core:create_retranslator [12/02/2013 11:46] alek |
en:sidebar:remoteapi:apiref:core:create_retranslator [07/04/2014 08:29] (current) |
| name | new retranslator name (at least 4 characters) | | | name | new retranslator name (at least 4 characters) | |
| config | retranslator configuration | | | config | retranslator configuration | |
| protocol | protocol ID (see [[../format/retranslator#Configuration|Data format: Retranslator configuration]]) | | | protocol | protocol ID (see [[../retranslator/update_config|Retranslators: Update configuration]]) | |
| server | retranslation server | | | server | retranslation server | |
| port | port (for all protocols except NIS) | | | port | port (for all protocols except NIS) | |
"flags":<unit> /* applied data flags */ | "flags":<uint> /* applied data flags */ |
</code> | </code> |
You can find the format of “item” in the chapter [[../format/retranslator|Data format: Retranslators]]. | You can find the format of “item” in the chapter [[../format/retranslator|Data format: Retranslators]]. |
