Differences
en:sidebar:remoteapi:apiref:core:create_resource [18/06/2015 16:58] mast |
en:sidebar:remoteapi:apiref:core:create_resource [18/06/2015 18:58] |
{{indexmenu_n>6}} | |
====== Create resource ====== | |
To create a new resource, use the command **core/create_resource**: | |
<code javascript> | |
svc=core/create_resource¶ms={"creatorId":<long>, | |
"name":<text>, | |
"dataFlags":<uint>, | |
"skipCreatorCheck":<bool>} | |
</code> | |
===== Parameters ===== | |
^ Name ^ Description ^ | |
| creatorId | ID of a user who will be assigned a creator for a new resource | | |
| name | name of a new resource (at least 4 characters) | | |
| dataFlags | data flags for the response (see [[../format/resource|Data format: Resources]])| | |
| skipCreatorCheck | special flag (see below), 1 - enable| | |
:!: Clarification for ''skipCreatorCheck'': if non-account user created items then it is impossible to create account for such user later; in order to create resource for such user please use skipCreatorCheck=1. The flag is used for that case only. Such limitation exists to protect one's hierarchy. | |
===== Response ===== | |
"item":{ /* resource created */ | |
"flags":<uint> /* applied data flags */ | |
</code> | |
You can find the format of “item” in the chapter [[../format/resource|Data format: Resources]]. | |
