en:sidebar:remoteapi:apiref:core:create_resource [12/02/2013 11:36] alek |
en:sidebar:remoteapi:apiref:core:create_resource [18/06/2015 16:58] mast |
Line 7: | Line 7: | ||
svc=core/create_resource¶ms={"creatorId":<long>, | svc=core/create_resource¶ms={"creatorId":<long>, | ||
"name":<text>, | "name":<text>, | ||
- | "dataFlags":<uint>} | + | "dataFlags":<uint>, |
+ | "skipCreatorCheck":<bool>} | ||
Line 15: | Line 16: | ||
| name | name of a new resource (at least 4 characters) | | | name | name of a new resource (at least 4 characters) | | ||
| dataFlags | data flags for the response (see [[../format/resource|Data format: Resources]])| | | dataFlags | data flags for the response (see [[../format/resource|Data format: Resources]])| | ||
+ | | skipCreatorCheck | special flag (see below), 1 - enable| | ||
+ | :!: Clarification for ''skipCreatorCheck'': if non-account user created items then it is impossible to create account for such user later; in order to create resource for such user please use skipCreatorCheck=1. The flag is used for that case only. Such limitation exists to protect one's hierarchy. | ||
Line 22: | Line 26: | ||
- | "flags":<unit> /* applied data flags */ | + | "flags":<uint> /* applied data flags */ |
You can find the format of “item” in the chapter [[../format/resource|Data format: Resources]]. | You can find the format of “item” in the chapter [[../format/resource|Data format: Resources]]. |
