en:sidebar:remoteapi:apiref:core:check_accessors [12/03/2015 14:30] mast |
en:sidebar:remoteapi:apiref:core:check_accessors [09/10/2015 08:50] stan [Response] |
Line 1: | Line 1: | ||
{{indexmenu_n>5}} | {{indexmenu_n>5}} | ||
- | ====== Getting unit access rights list for child accounts ====== | + | ====== Getting unit access rights list for child users ====== |
- | In order to get unit access rights list for child accounts please invoke **core/check_accessors** command: | + | In order to get unit access rights list for child users please invoke **core/check_accessors** command: |
Line 17: | Line 17: | ||
"<unit_id>": { /* unit id */ | "<unit_id>": { /* unit id */ | ||
- | "<acc_id>": { /* account id */ | + | "<acc_id>": { /* user id */ |
"acl": <uint>, /* inherited unit access rights, they are put as mask on direct access rights, | "acl": <uint>, /* inherited unit access rights, they are put as mask on direct access rights, | ||
if inherited access rights prohibit -- result access right prohibit */ | if inherited access rights prohibit -- result access right prohibit */ | ||
"dacl": <uint> /* if flags:1 set; direct unit access rights (set by unit owner) */ | "dacl": <uint> /* if flags:1 set; direct unit access rights (set by unit owner) */ | ||
- | ... /* other account ids (if any) */ | + | ... /* other user ids (if any) */ |
... /* other unit ids (if requested) */ | ... /* other unit ids (if requested) */ | ||
</code> | </code> |
