Differences
Link to this comparison view
Next revision
Previous revision
en:pro:remoteapi:codesamples:search [06/03/2013 15:54]
zuve
en:pro:remoteapi:codesamples:search [18/01/2016 12:55]
stan [search units by creator]
Line 14: Line 14:
  "​itemId":​48,​  "​itemId":​48,​
  "​flags":​1025  "​flags":​1025
- }&sid=<​your_sid>​+ }&ssid=<​your_sid>​
 </​code>​ </​code>​
Line 65: Line 65:
           "​from":​0,​           "​from":​0,​
           "​to":​0xffffffff           "​to":​0xffffffff
 </​code>​ </​code>​
 Asterisk in the parameter //​propValueMask//​ means that in the result array there will be users with any values in the field //​sys_name//​ (that is users of any names). It means all available users will be present in the result. Value "​1"​ of the parameter //flags// means that basic information about the item must be included in the result. Detailed information about user flags is given in the chapter [[../​apiref/​format/​user]]. Values of the parameters //from// and //​to// ​ which equals to 0 and 0xffffffff accordingly,​ indicate that all found users should be returned. Asterisk in the parameter //​propValueMask//​ means that in the result array there will be users with any values in the field //​sys_name//​ (that is users of any names). It means all available users will be present in the result. Value "​1"​ of the parameter //flags// means that basic information about the item must be included in the result. Detailed information about user flags is given in the chapter [[../​apiref/​format/​user]]. Values of the parameters //from// and //​to// ​ which equals to 0 and 0xffffffff accordingly,​ indicate that all found users should be returned.
Line 100: Line 100:
 +</​code>​
 +==== Search units by creator ====
 +<​code>​
 +<​your_wialon_pro_address>/​ajax.html?​svc=core/​search_items&​
 + params={
 + "​spec":​{
 + ​ "​itemsType":"​avl_unit",​
 + "​propName":"​22sys_user_creator",​
 +    "​propValueMask":"​22ac745a8ec8eb54469607d30bfeffb807", ​     /* creators "​gd"​ property */
 + "​sortType":"​sys_name"​
 +                "​force":​1,​
 +          "​flags":​1,​
 +          "​from":​0,​
 +          "​to":​0xffffffff
 + }&​ssid=<​your_sid>​
 +</​code>​
 +Response:
 +<code javascript>​
 +    searchSpec: {
 +        itemsType: "​avl_unit",​
 +        propName: "​sys_user_creator",​
 +        propValueMask:​ "​ac745a8ec8eb54469607d30bfeffb807",​
 +        sortType: "​sys_name"​
 +    dataFlags: 1,
 +    totalItemsCount:​ 3,
 +    indexFrom: 0,
 +    indexTo: 2,
 +    items: [{
 +        nm: "​unit1",​
 +        cls: 3,
 +        id: 554
 +        nm: "​unit2",​
 +        cls: 3,
 +        id: 558
 +        nm: "​unit3",​
 +        cls: 3,
 +        id: 559
 </​code>​ </​code>​
