Resources
Depending on set flags format of response can differ.
This chapter describes flags that can be applied to resources and parts of resulting JSON which they are responsible for. If you specify several flags, then parts will be united into one JSON.
:!: All flags are only used in DEC format.
Resource flags:
Value HEX Value DEC Description
0x00000001 1 base flag
0x00000002 2 custom properties
0x00000004 4 billing properties
0x00000008 8 custom fields
0x00000020 32 messages
0x00000040 64 GUID
0x00000080 128 administrative fields
0x00000100 256 drivers
0x00000200 512 jobs
0x00000400 1024 notifications
0x00000800 2048 POIs
0x00001000 4096 geofences
0x00002000 8192 report templates
0x00004000 16384 list of auto attachable units for drivers
0x00008000 32768 driver groups
0x00010000 65536 trailers
0x00020000 131072 trailer groups
0x00040000 262144 list of auto attachable units for trailers
0x00080000 524288 orders
0x00100000 1048576 geofences groups
0x00200000 2097152 tags (passengers)
0x00400000 4194304 automatic binding list of units (for tags)
0x00800000 8388608 tags groups(passengers)
0x3FFFFFFFFFFFFFFF 4611686018427387903 set all possible flags to resource
General properties
Flag - 0x00000001
	"nm":<text>,	/* name */
	"cls":<uint>,	/* superclass ID: "avl_resource" */
	"id":<uint>,	/* resource ID */
	"mu":<uint>,	/* measure units: 0 - si, 1 - us, 2 - imperial, 3 - metric with gallons */
	"uacl":<uint>	/* current user access level for resource */
Custom properties
Flag - 0x00000002
You can store any resource data you need in custom properties.
	"prp":{				/* custom properties */
		"emails":"[<text>]",		/* list of e-mails for jobs */
		"nf_rep_emails":"[<text>]",	/* list of e-mail for notifications */
		"phones":"[<text>]",		/* list of phone numbers for job "Send fuel information by e-mail or SMS" */
	"ftp": {				/* FTP settings */
		"hs":<text>,			/* host */
		"lg":<text>,			/* login */
		"pt":<text>,			/* directory path */
		"ch": <uint>,			/* FTP settings validity: 1-yes, 0-no */
		"tp": <uint>,			/* use wialon hosting FTP: 1 - yes, 0 - no */
		"fl": <uint>			/* is wialon hosting FTP available: 1 - yes, 0 - no */
Billing
Flag - 0x00000004
	"crt":<uint>,	/* creator ID */
	"bact":<uint>,	/* account ID */
	"bpact":<uint>	/* parrent account ID */
Custom fields
Flag - 0x00000008
	"flds":{	/* custom fields */
		"<uint>":{	/* sequence number */
			"id":<uint>,	/* ID */
			"n":<text>,	/* name */
			"v":<text>	/* value */
	"fldsmax":<long>,	/* maximal count of custom fields (-1 - unlimited) */
Messages
Flag - 0x00000020
After setting this flag you can receive resource messages.
GUID
Flag - 0x00000040
	"gd":<text>	/* resource GUID */
Administrative fields
Flag - 0x00000080
	"aflds":{	/* administrative fields */
	"afldsmax":<long>,	/* maximal count of administrative fields (-1 - unlimited) */
Drivers
Flag - 0x00000100
	"drvrs":{
		<text>:{	/* sequence number of driver */
			"id":<long>,	/* ID */
			"c":<text>,	/* code */
			"pwd":<text>,   /* password for mobile authorization */
			"ej":<text>,    /* extentended JSON */
			"jp": {			/* custom fields */
				<text>:<text>,		/* name: value */
			"ds":<text>,	/* description */
			"p":<text>,	/* phone number */
			"r":<double>,	/* image aspect ratio */
			"ck":<ushort>	/* check sum (CRC16) */
			"bu":<long>,	/* binded unit */
			"pu":<long>,	/* previous binded unit */
			"bt":<uint>,	/* time of last binging/unbinding */
			"pos":{		/* last position, null - if driver is bound to unit */
				"y":<double>,	/* latitude */
				"x":<double>	/* longitude */
			infr: { /*parameters for analysis infringements of work and rest of drivers AETR */
				"a": <uint>,	/* current activity */
				"t": <uint>,	/* the start time of this activity */
				"ud": <uint>,	/* duration of uninterrupted driving before the current activity */
				"ur": <uint>,	/* duration of uninterrupted rest before the current activity */
				"uil": <uint>,	/* allowed duration of uninterrupted driving */
				"uim": <uint>,	/* duration of uninterrupted driving to which the violation is infringement minor */
				"uis": <uint>,	/* duration of uninterrupted driving to which the violation is infringement serious (above - very serious) */
				"uir": <uint>,	/* duration of required rest */
				"ddt": <uint>,	/* daily driving time before the current activity */
				"dbt": <uint>,	/* start time of daytime activity */
				"ddc": <uint>,	/* allowed number of prolonged daily driving in this week */
				"ddil": <uint>,	/* allowed duration of daily driving */
				"ddim": <uint>,	/* allowed duration of daily driving (minor infringement ) */
				"ddis": <uint>,	/* allowed duration of daily driving (serious infringement(above very serious)) */
				"wdt": <uint>,	/* duration of weekly driving before the current activity */
				"wdil": <uint>,	/* allowed duration of weekly driving */
				"wdim": <uint>,	/* allowed duration of weekly driving (minor infringement) */
				"wdis": <uint>,	/* allowed duration of weekly driving (serious infringement(above very serious)) */
				"twdt": <uint>,	/* duration for two weeks of driving before the current activity */
				"twdil": <uint>,/* allowed duration for two weeks of driving */
				"twdim": <uint>,/* allowed duration for two weeks of driving (minor infringement) */
				"twdis": <uint>,/* allowed duration for two weeks of driving (serious infringement(above very serious)) */
				"drt": <uint>,	/* duration of the previous daily rest */
				"drd": <uint>,	/* duration of the required daily rest */
				"dril": <uint>,	/* time before which daily rest should occure */
				"drim": <uint>,	/* time before which an infringement is considered to be minor */
				"dris": <uint>,	/* time before which an infringement is considered to be serious(above very serious) */
				"wrt": <uint>,	/* duration of the previous weekly rest */
				"wrd": <uint>,	/* duration of the required weekly rest */
				"wril": <uint>,	/* time before which weekly rest should occure */
				"wrim": <uint>,	/* time before which an infringement is considered to be minor */
				"wris": <uint>	/* time before which an infringement is considered to be serious(above very serious) */
	"drvrsmax":<long>	/* maximal count of drivers (-1 - unlimited) */
Jobs
Flag - 0x00000200
	"ujb":{
		<text>:{		/* sequence number of job */
			"d":<text>,		/* description */
			"m":<uint>,		/* maximal allowed executions count */
			"st":{			/* state */
				"e":<uint>,		/* active/inactive */
				"c":<uint>,		/* executions count */
				"l":<uint>		/* last execution time */
			"act":<text>		/* action type */
	"ujbmax":<long>,	/* maximal count of jobs (-1 - unlimited) */
Types of actions are described in the chapter Jobs: detailed information.
Notifications
Flag - 0x00000400
	"unf":{
		<text>:{	/* sequence number of notification */
			"ta":<uint>,	/* activation time */
			"td":<uint>,	/* deactivation time */
			"ma":<uint>,	/* maximal alarms count (0 - unlimited) */
			"fl":<uint>,	/* notification types */
			"ac":<uint>,	/* alarms count */
			"un":[<long>],	/* array of units IDs */
			"act":[<text>],	/* actions list */
			"trg":<text>,	/* type of control */
			"crc":<long>	/* check sum of binary view of notification */
	"unfmax":<long>,	/* maximal count of notifications (-1 - unlimited) */
Action types, control types and notification flags are described in the chapter Notifications: detailed information.
POIs
Flag - 0x00000800
	"poi":{
		<text>:{	/* sequence number of POI */
			"x":<double>,	/* longitude */
			"t":<double>,	/* image aspect ratio */
			"i":<short>,	/* check sum of image (CRC16) */
			"e":<ushort>	/* check sum of POI (CRC16) */
	"poimax":<long>		/* maximal count of POIs (-1 - unlimited) */
Geofences
Flag - 0x00001000
	"zl":{
		<text>:{	/* sequence number of geofence */
			"f":<uint>,	/* flags */
			"t":<int>,	/* type: 1 - line, 2 - polygon, 3 - circle */
			"e":<ushort>	/* check sum (CRC16) */
			"b":{	/* configuration for rendering geofences */
				"min_x":<double>,	/* minimal longitude */
				"min_y":<double>,	/* minimal latitude */
				"max_x":<double>,	/* maximal longitude */
				"max_y":<double>,	/* maximal latitude */
				"cen_x":<double>,	/* longitude of center  */
				"cen_y":<double>	/* latitude of center */
	"zlmax":<long>	/* maximal count of geofences (-1 - unlimited) */
Geofence flags are described in the chapter Geofences: detailed information.
Report templates
Flag - 0x00002000
	"rep":{
		<text>:{	/* sequence number of template */
			"ct":<text>,	/* template type */
			"c":<ushort>	/* check sum (CRC16) */
	"repmax":<long>	/* maximal count of templates (-1 - unlimited) */
Types of templates are described in the chapter Get templates data.
List of auto attachable units for drivers
Flag - 0x00004000
	"drvrun":[<long>]	/* array IDs of auto attachable units */
Driver groups
Flag - 0x00008000
	"drvrsgr":{	/* driver groups */
		<text>:{	/* sequence number of group */
			"id":<long>,	/* group ID */
			"drs":[<uint>]	/* array of drivers IDs */
	"drvrsgrmax":<long>	/* maximal count of driver groups (-1 - unlimited) */
Trailers
Flag - 0x00010000
	"trlrs":{	/* trailers */
		<text>:{	/* sequence number of trailer */
			"id":<long>,	/* trailer ID */
			"jp":{		/* custom fields */
			"ck":<short>,	/* check sum of image */
			"bt":<uint>,	/* time of last binding/unbinding */
			"pos":{		/* position */
	"trlrsmax":<long>	/* maximal count of trailers (-1 - unlimited) */
Trailer groups
Flag - 0x00020000
	"trlrsgr":{	/* trailer groups */
			"drs":[<uint>]	/* array of trailers IDs */
	"trlrsgrmax":<long>	/* maximal count of trailer groups (-1 - unlimited) */
List of auto attachable units for trailers
Flag - 0x00040000
	"trlrun":[<long>]	/* array IDs of auto attachable units */
Orders
Флаг - 0x00080000
   "orders":{
        "<uint>": {      /* order number, the same as in "id" param */
		    "id":<uint>,	/* order id within resource */
		    "n":<text>,	        /* order name */
		    "p":{		/* user-defined object content */
		    "f":<bool>,	        /* order flags: 1 - order would be marked as completed if there were at least one message within order area with zero speed in it */
		    "tf":<uint>,        /* lower bound of order completion time */
		    "tt":<uint>,        /* upper bound of order completion time  */
		    "uid":<uint>,	/* unique id (is used as unique key in order history) */
		    "r":<uint>,	        /* order point radius */
		    "y":<double>,	/* order point lattitude */
		    "x":<double>,	/* order point longitude */
		    "u":<long>,	        /* unit id */
		    "s":<uint>,	        /* order status: 0 - inactive (no unit assigned), 1 - active (unit assigned), 2 - completed in time, 3 - completed overdue, 4 - cancelled (not used) */
		    "st":<uint>	        /* last status modification time */
Geofences groups
Flag - 0x00100000
	"zg":{	/* geofences groups */
			"zns":[<uint>]	/* array of geofences IDs */
	"zgmax":<long>	/* maximal count of geofences groups (-1 - unlimited) */
Tags (passengers)
Flag - 0x00200000
"item": {
    "tags": {
	<uint>: {			/* tag id*/
	    "id": <uint>,		/* tag id*/
	    "n": <text>,		/* tag name*/
	    "c": <text>,		/* tag code */
	    "jp": {<text>:<text> },	/* custom fields, key:value */
	    "r": <double>,		/* image aspect ratio */
	    "bu": <long>,		/* binded unit */
	    "pu": <long>,		/* previous binded unit */
	    "bt": <uint>,		/* last binding/unbinding time */
	    "tz": <int>,		/* time zone */
	    "art": <int>,		/* automatic time unbinding  */
	    "pos": {			/* position */
		"y": <double>,		/* latitude */
		"x": <double>		/* longitude */
    tagsmax: -1				/* maximum number of tags */
Automatic binding list of units (for tags)
Flag - 0x00400000
    "tagrun":[<long>]	/* array of units ID's for automatic binding */
Tags groups(passengers)
Flag - 0x00800000
    "tagsgr": {
	<long>: {		/* group ID */
	    "id": <long>,	/* group ID */
	    "n": <text>,	/* group name */
	    "d": <text>,	/* description */
	    "tgs": [<uint>]	/* tags ID's array */
    "tagsgrmax": -1		/* maximum number of groups */
