Create, update, delete billing plan
You can use this command for billing plan creation, updating, deleting:
svc=account/update_billing_plan¶ms={"callMode":<text>,
"plan":{
"name":<text>,
"rename":<text>,
"servicesModCounter":<uint>,
"historyPeriod":<int>,
"flags":<uint>,
"denyBalance":<double>,
"blockBalance":<double>,
"minDaysCounter":<int>,
"currencyFormat":<text>,
"descr":<text>,
"email":<text>,
"hwTypes":{
"<hw_id>":
"name": <uint>
"parent": <text>,
"personal":
"services": <object>
Parameters
| Name | Description |
| callMode | request type (create, update, delete) |
| name | billing plan name (unique field) |
| rename | new billing plan name |
| servicesModCounter | counter shows how many times services list being modified |
| historyPeriod | time to store unit messages, days |
| flags | billing plan flags (see below) |
| denyBalance | min balance below which block occurs |
| blockBalance | min balance below which services block occurs |
| minDaysCounter | min days count below whoch block occurs |
| currencyFormat | currency format |
| descr | billing plan description |
| email | email box |
Restrictions for rename:
1. top billing name editing is restricted;
2. setting already existed billing name to another plan is restricted (no dublicates allowed).
Billing plan flags
| Flag | Description |
| 0x01 | block users, if the balance is less than block balance |
| 0x02 | forbid to login to the system and stop account functioning if the balance is less than deny balance |
| 0x08 | limit device types by assigned |
| 0x10 | limit device types by any except assigned |
| 0x20 | every day decrease the days counter value, and block account when remained days value reaches the minimum value |
HW Types
| <hw_name> | put correct hw name here |
| id | hardware id |
Services
| cost | cost table |
| descr | service description |
| flags | define action: 0 - none, 1 - create/update, 2 - delete |
| interval | 0 - none, 1 - hourly, 2 - daily,
3 - weekly, 4 - monthly |
| maxUsage | amount of items available |
| name | service name |
| type | service type: 1 - on demand, 2 - periodic |
Please visit this page to get more info about services.
Response
"parent":<text>, /* parent billing plan name */
"name":<text>, /* billing plan name */
"servicesModCounter":<uint>, /* services modification counter */
"historyPeriod":<uint>, /* history period to store messages, in days (if 0 - unlimited) */
"flags":<uint>, /* billing plan flags */
"denyBalance":<int>, /* deny balance */
"blockBalance":<int>, /* block balance */
"minDaysCounter":<int>, /* minimum days counter */
"currencyFormat":<text>, /* currency format */
"descr":<text>, /* description */
"email":<text>, /* email */
"mapserverTags":<text>, /* map server tags */
"hwTypes":{ /* hardware object */
"<hw_id>": /* hardware id */
"name": <text> /* hardware name */
/* smtp server settings */
"smtp_host":<text>, /*server URL, example "smtps://smtp.yandex.ru"*/
"smtp_login":<text>, /* login, example "savraska.nik@yandex.ru" */
"smtp_port":<text>, /* port, example "4657" */
"personal":
"services": <object> /* services object (see below) */
"combined":
Services
"services":{ /* service object where keys are correct service names */
"<service_name>":{ /* put correct service name instead of <service_name> */
"type": <uint>, /* type: 1 - on demand; 2 - periodic */
"maxUsage": <int>, /* count of active resources of current service */
"cost": <text>, /* maximal resources count */
"interval": <uint>, /* cost table */
"descr": <text>, /* interval: 0 - none, 1 - hourly, 2 - daily, 3 - weekly, 4 - monthly*/
"flags": <uint>
Please go here to see services list.
