svc=file/put¶ms={"itemId":<long>, "storageType":<uint>, "path":<text>, "writeType":<uint>, "eventHash":<text>}
| Parameter | Description |
| itemId | element id |
| storageType | storage type: 1 - public(all users may see/download files ), 2 - protected (that users may see/down- load files who being grant rights) |
| path | relative path from root folder to the file |
| writeType | write type: 0 - overwrite a file, 1 - append to a file content, 2 - do not overwrite if file exists |
| eventHash | event name which will be generated af- ter processing the data |
There is no way for 'file' and 'folder' to coexist with the same names (e.g. text file 'readme' and 'readme'-folder) because Linux treats them as the same entity though with different attributes.
In order to upload some files, put them using POST-request with some params (multipart/form-data), e.g.:
Request URL: https://hst-api.wialon.com/wialon/ajax.html?svc=file/put&sid=<sid>
Request Method: POST
Connection: keep-alive
Content-Length:333998
Cache-Control:max-age=0
Content-Type:multipart/form-data; boundary=----WebKitFormBoundaryMpLUirMexsfCGaJP
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Charset: windows-1251,utf-8;q=0.7,*;q=0.3
Accept-Encoding: gzip,deflate,sdch
Accept-Language: ru,en-US;q=0.8,en;q=0.6
------WebKitFormBoundaryhJ0ZukEcpN7MgFnC
Content-Disposition: form-data; name="params"
{"itemId":439,"storageType":"1","path":"1","writeType":0,"eventHash":"jUploadForm1414572405484"}
Content-Disposition: form-data; name="eventHash"
Content-Disposition: form-data; name="f"; filename="one-file"
Content-Type: application/octet-stream
------WebKitFormBoundaryhJ0ZukEcpN7MgFnC--
{ "<filename>":"<result>", /* <filename> - uploaded file name */ /* <result> - request result; 0 - failed, 1 - OK */ ... }
