Table of Contents
Import of POIs
To import POIs, use the command exchange/import_pois_save:
svc=exchange/import_pois_save&params={"itemId":<long>,
				      "pois":[{
						"n":<text>,
						"d":<text>,
						"img":<text>,
						"x":<double>,
						"y":<double>,
						"r":<uint>,
						"f":<uint>,
						"c":<uint>,
						"tc":<uint>,
						"ts":<uint>,
						"min":<uint>,
						"max":<uint>
:!: Current request can't be executed simultaneously with any request from this chapter and following requests:
Parameters
Name Description
itemId resource ID
id POI ID
pois array of POIs IDs
img HEX string
You can find the description of other parameters in the chapter get_poi_data.
Response
<int>		/* quantity of updated POIs */
