POIs: upload/delete image
This method is deprecated. POI were icorporated into Geofences 29.02.2016 (see. resource/upload_zone_image)
To upload an image for a POI, use the command resource/upload_poi_image:
svc=resource/upload_poi_image&params={"itemId":<long>,
				      "poiId":<long>,
				      "eventHash":<text>}
:!: To delete an image, use the command POIs: create, edit, delete.
Parameters
Name Description
itemId resource ID
poiId POI ID
eventHash event name, which will be generated after uploading the image (optional parameter)
To upload an image, use a POST request with multiple contents (multipart/form-data), where one part contains parameters and the other contains the image.
For example:
Request URL: https://hst-api.wialon.com/wialon/ajax.html?svc=resource/upload_poi_image&sid=8157df114c0e601f0f31091c3c2ac53d
Request Method: POST
Host: hst-api.wialon.com
Connection: keep-alive
Content-Length: 31753
Cache-Control: no-cache
Content-Type: multipart/form-data; boundary=----WebKitFormBoundaryX2W1y7AVnQkXQAM0
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Charset: windows-1251,utf-8;q=0.7,*;q=0.3
Accept-Encoding: gzip,deflate,sdch
Accept-Language: ru,en-US;q=0.8,en;q=0.6
------WebKitFormBoundaryX2W1y7AVnQkXQAM0
Content-Disposition: form-data; name="params"
{"itemId":717314,"poiId":1,"eventHash":"jUploadForm1372768029714"}
Content-Disposition: form-data; name="eventHash"
Content-Disposition: form-data; name="poi_dlg_props_upload_image"; filename="zZeVUgLEJXE.jpg"
Content-Type: image/jpeg
------WebKitFormBoundaryX2W1y7AVnQkXQAM0--
Response
{}	/* empty object if execution successful, if not - error code */
To be sure that the image has been uploaded, you can execute the command Events:
	"tm":<uint>,				/* current server time (UTC) */
	"events":[
			"i":<long>,			/* POI ID (-1 if unknown) */
			"d":{				/* data */
				"hash":<text>		/* upload is complete */
