Add/remove units
To add units into a group or remove them from it, use the command unit_group/update_units:
svc=unit_group/update_units&params={"itemId":<long>,
				    "units":[<long>]}
Parameters
Name Description
itemId unit group ID
units array of units IDs
Note: The units parameter must contain IDs of both objects already added and that should be added. In the case of deletion, you must list the IDs of the objects that should remain in the group.
Response
	"u":[<long>]	/* array of units IDs */
Follow us on Facebook Gurtam Wialon Twitter Gurtam Wialon info@gurtam.com   |   Copyright © 2002-2025 Gurtam
