Update check points
To update the list of route check points, use the command update_checkpoints:
svc=route/update_checkpoints&params={"itemId":<long>,
				     "checkPoints":[{}]}
Parameters
Name Description
itemId route ID
checkPoints array of check points
Check points formats according to their type:
Check point from map
	"f":1,		/* point type */
	"n":<text>,	/* name */
	"y":<double>,	/* latitude */
	"x":<double>,	/* longitude */
	"r":<uint>	/* radius */
Check point from geofence
	"f":2,		/* point type */
	"gz":{		/* information about geofence */
		"d":<text>,	/* description */
		"id":<long>,	/* ID */
		"t":<byte>,	/* type: 1 - line, 2 - polygon, 3 - circle */
		"w":<uint>,	/* line thickness or circle radius */
		"f":<uint>,	/* geofence flags */
		"c":<uint>,	/* color (ARGB) */
		"b":{		/* additional parameters */
			"min_x":<double>,	/* minimal longitude */
			"min_y":<double>,	/* minimal latitude */
			"max_x":<double>,	/* maximal longitude */
			"max_y":<double>,	/* maximal latitude */
			"cen_x":<double>,	/* longitude of center  */
			"cen_y":<double>	/* latitude of center */
		"p":[		/* array of geofence points */
Geofence flags are described in the chapter Geofences: detailed information.
Check point from units
	"f":4,		/* point type */
	"u":<long>,	/* unit ID */
Response
	"rpts":[	/* array of check points */
			"f":<uint>,	/* type */
			"u":<long>,	/* unit ID, 0 - if check point is not of the type "check point from units" */
