Update parameters used in reports
To update parameters used in reports, use the command unit/update_report_settings:
svc=unit/update_report_settings&params={"itemId":<long>,
					"params":{
						"speedLimit":<uint>,
						"maxMessagesInterval":<uint>,
						"dailyEngineHoursRate":<uint>,
						"urbanMaxSpeed":<uint>,
						"mileageCoefficient":<double>,
						"speedingTolerance":<uint>,
						"speedingMinDuration":<uint>,
						"speedingMode":<uint>
						"fuelRateCoefficient":<uint>
Parameters
Name Description
itemId unit ID
params parameters
speedLimit speed limit, km/h
maxMessagesInterval maximum interval between messages, seconds
dailyEngineHoursRate daily engine hours rate, hours
urbanMaxSpeed urban speed limit, km/h
mileageCoefficient mileage coefficient
speedingTolerance allowed speeding, km/h (used if speedingMode = 1)
speedingMinDuration min speeding time, seconds
speedingMode speeding detection mode:
0 - use speedLimit,
1 - use map data
fuelRateCoefficient Consumption by rates, l/100km
If speedingMode = 0 and speedLimit = 0 then no any speeding table is built.
Response
{}	/* empty object if execution successful, if not - error code */
