Table of Contents
Edit unit image
To assign the image to unit, use the command unit/update_image:
Same as at the other (e.g. when you copy unit)
svc=unit/update_image&params={"itemId":<long>,
			      "oldItemId":<long>}
From library:
			      "libId":<long>,
			      "path":<text>}
Parameters
Name Description
itemId new unit ID
oldItemId old unit ID
libId ID of resource with image (for default library - 0)
path image file location
Response
{}	/* empty object if execution successful, if not - error code */
