Users
Depending on set flags format of response can differ.
This chapter describes flags that can be applied to users and parts of resulting JSON which they are responsible for. If you specify several flags, then parts will be united into one JSON.
:!: All flags are only used in DEC format.
User flags:
Value HEX Value DEC Description
0x00000001 1 base flag
0x00000002 2 custom properties
0x00000004 4 billing properties
0x00000008 8 custom fields
0x00000020 32 messages
0x00000040 64 GUID
0x00000080 128 administrative fields
0x00000100 256 other properties
0x00000200 512 notifications
0x3FFFFFFFFFFFFFFF 4611686018427387903 set all possible flags to user
General properties
Flag - 0x00000001
	"nm":<text>,	/* user name */
	"cls":<uint>,	/* superclass ID: "user" */
	"id":<uint>,	/* user ID */
	"mu":<uint>,	/* measure units: 0 - si, 1 - us, 2 - imperial, 3 - metric with gallons */
	"uacl":<uint>	/* current user access level for user*/
Custom properties
Flag - 0x00000002
You can store any user data you need in custom properties. Usually, such settings are user's e-mail, map position after launching etc.
	"prp":{
		"cfmt":<text>,		/* coordinates format: "0" - degrees and minutes, "1" - degrees */
		"email":<text>,		/* user e-mail */
		"msc":<text>,		/* map position after launching: "0" - by default, "1" - saved */
		"poisrv":<text>,	/* render POIs on server */
Billing
Flag - 0x00000004
	"crt":<uint>,	/* creator ID */
	"bact":<uint>	/* account ID */
Custom fields
Flag - 0x00000008
	"flds":{		/* custom fields */
		<text>:{		/* sequence number */
			"id":<uint>,		/* ID */
			"n":<text>,		/* name */
			"v":<text>		/* value */
	"fldsmax":<long>		/* maximal count of custom fields (-1 - unlimited) */
Messages
Flag - 0x00000020
After setting this flag you can receive messages from unit.
GUID
Flag - 0x00000040
	"gd":<text>	/* user GUID */
Administrative fields
Flag - 0x00000080
	"aflds":{	/* administrative fields */
	"afldsmax":<long>,	/* maximal count of administrative fields (-1 - unlimited) */
Other properties
Flag - 0x00000100
	"fl":<uint>,	/* user settings flags */
	"hm":<text>,	/* host mask */
	"ld":<uint>,	/* last login time */
	"pfl":<uint>,	/* parent flags */
	"ap":{
	    "type":<uint>, 	/* two-factor autentification type */
	    "phone":<text>	/* two-factor autentification type */
The list of user settings flags is given in the chapter Set user settings flags.
Notifications
Flag - 0x00000200
	"usnf":{	/* user notifications */
			"id":<long>,		/* ID */
			"t":<uint>,		/* lifetime (sec) */
			"d":<text>,		/* text of notification */
			"h":<text>,		/* subject */
			"s":<text>		/* sender */
