Check event updates
To get all event updates of all units added into session use events/check_updates:
svc=events/check_updates&params={"lang":<text>,
				 "measure":<uint>,
				 "detalization":<uint>}
Parameters
All parameters are optional.
Param Description Default value
lang languare (2-symbol code) en
measure measure:
0 - si,
1 - us,
2 - imperial
0
detalization output flags (see below) 0x7
Output flags
Flag Descrition
0x1 Basic JSON: event start - event end
0x2 Specified detector data
0x4 User parameters (those which user stated for this event)
0x10 Full JSON. Every detector treats it its own way
0x20 Formatted value
Sensor type
type
value
Description How events registered
1 Switcher sensors:
engine operation;
digital;
engine efficiency;
private mode;
alarm trigger;
counter(switch to ON/to OFF)
Events are registered from ON position
to OFF position.
2 Instant sensors:
odometer;
relative engine hours;
instant fuel consumption;
counter(instant)
Events are registered from the first non-
zero value to the last non-zero one.
3 Differential sensors : mileage;
engine hours;
impulse fuel consumption;
absolute fuel consumption;
counter(differential + with overflow);
fuel level impulse sensor
Events are registered from start of value
increasing to the end of it.
4 Analog sensors: temperature;
engine rpm;
voltage;
weight sensor;
accelerometer;
temperature coefficient;
custom
Events are not registered.
Response
0x1 flag
Returns basic JSON (equal to all sensor groups)
"<type_name>": {
	"<sensor_id>": {
		"from": {
			"t":<uint>,	/* time (UNIX-time) */
			"y":<double>,	/* latitude */
			"x":<double>	/* longitude */
		"to": {
		"m":<uint>,		/* last message received time */
		"f":<uint> 		/* service flag */
0x2 flag
Returns specified detector data
"ignition": {
	"<sensor_id>":
			    "state":<uint>,	/* state: 0 - off, 1 - on */
			    "type": 1,		/* sensor type: switcher sensor */
			    "hours":<uint>,	/* engine hours for all history, sec */
			    "switches":<uint>,	/* number of swithes for all hoistory */
			    "value":<bool>	/* current value */
Here are listed all sensor types for sensors:
"sensors": {
	"<sensor_id1>":
	"<sensor_id2>":
			    "type": 2,			/* sensor type: instant sensor */
			    "counter":<uint>,		/* message sequence conuter in event */
			    "summary":<uint>,		/* value summary in event */
			    "total_counter":<uint>,	/* number of messages in history */
			    "total_summary"<uint>,	/* value summary in history */
			    "value":<double> 		/* last value; if -348201.3876 -- value unknown */
	"<sensor_id3>":
			    "type": 3,			/* sensor type: differential sensor */
			    "counter":<uint>,		/* value sum in event */
			    "total_counter":<uint>,	/* value sum in history */
	"<sensor_id4>":
			    "type": 4,			/* sensor type: analog sensor */
"lls": {
	"<sensor_id>":
			    "value":<double>, 		/* last message value with calculated level */
			    "level":<double>, 		/* average median value  (FLS filtration value is used) */
			    "filled":<double> 		/* fuel filled */
"trips": {
		"state":<bool>,		/* state: 0 - parking, 1 - trip, 2 - stop */
		"max_speed":<uint>,	/* max speed in trip */
		"curr_speed":<uint>,	/* current speed */
		"avg_speed":<uint>,	/* average speed according to distance */
		"distance":<uint>,	/* GPS mileage in trip */
		"odometer":<uint>,	/* distance for all trips */
		"course":<uint>,	/* course */
		"altitude":<uint>	/* altitude */
"counters": {
	"engine_hours": <uint>,   /* engine hours counter */
	"mileage": <uint>,        /* mileage counter */
	"bytes": <uint>           /* GPRS traffic counter */
0x4 flag
Returns user parameters Response depends on user definitions for current event.
"<type_name>": {
	"<sensor_id>": {
		"p":{	/* user-defined object content */
			"test":2,
			"foo":"bar",
			"trips":1
0x10 flag
Returns full JSON For sensors with both type=2 and type=3 (except FLS):
"sensors": {
	"<sensor_id>":
			    "msgs": [
					    "tm":<uint>,	/* message time, UNIX-time */
					    "v":<double>	/* value */
For FLS:
"lls": {
	"<sensor_id>": {
		"msgs": [
				"v":<double>,	/* value */
				"l":<double>	/* average median value  (FLS filtration value is used) */
0x20 flag
Returns formatted values
"ignition": {
	"sensor_id": {
		"format": {
			    "value":<text>	/* formatted value  (usually "On"/"Off") */
"sensors": {
	"sensor_id": {
		"format": {
			    "value":<text>	/* formatted value, depends on sensor type and format */
"trips": {
	"format": {
		"distance":<text>,		/* distance according to prev message */
		"avg_speed":<text>		/* average speed according to "distance"  */
"lls": {
	"sensor_id": {
		"format": {
			    "value":<text>,	/* formatted value, depends on sensor type and format */
			    "filled":<text>	/* fuel filled */
"counters": {
	"format": {
	"engine_hours":<uint>,   /* formatted value of engine hours counter */
	"mileage":<text>,        /* formatted value of mileage counter */
	"bytes":<uint>           /* formatted value of GPRS traffic counter */
