Update drive rank settings
svc=unit/update_drive_rank_settings&params={"itemId":<long>,
                                            "driveRank":
                                                    "acceleration":[
                                                             "flags":<uint>,
                                                             "min_value":<double>,
                                                             "max_value":<double>,
                                                             "min_speed":<uint>,
                                                             "max_speed":<uint>,
                                                             "min_duration":<uint>,
                                                             "max_duration":<uint>,
                                                             "validator_id":<long>,
                                                             "name":<text>,
                                                             "penalties":<uint>
                                                    "brake":[
                                                             "flags":<uint>,
                                                             "min_speed":<uint>,
                                                             "max_speed":<uint>,
                                                             "name":<text>,
                                                             "penalties":<uint>
                                                    "turn":[
                                                             "flags":<uint>,
                                                             "min_speed":<uint>,
                                                             "max_speed":<uint>,
                                                             "name":<text>,
                                                             "penalties":<uint>
                                                    "sensor":[
                                                             "flags":<uint>,
                                                             "min_speed":<uint>,
                                                             "max_speed":<uint>,
                                                             "sensor_id":<long>,
                                                             "name":<text>,
                                                             "penalties":<uint>
                                                    "speeding":[
                                                             "flags":<uint>,
                                                             "min_speed":<uint>,
                                                             "max_speed":<uint>,
                                                             "name":<text>,
                                                             "penalties":<uint>
                                                    "harsh":[
                                                             "flags":<uint>,
                                                             "min_speed":<uint>,
                                                             "max_speed":<uint>,
                                                             "name":<text>,
                                                             "penalties":<uint>
						    "global":
							    {"accel_mode":<uint>},
Parameters
It is optional to set evaluation criteria. DriveRank may contain empty object {}.
Params Description
accel_mode Penalties calculating method
0 - combined,
1 - by speed in messages,
2 - by по accelerometer values
itemId item ID
driveRank drive rank criteria parameters object
Evaluation criteria
acceleration acceleration
brake brake
turn turn
sensor sensor
speeding speeding
harsh harsh driving
Criteria settings
flags flags:
1 - penalties averaging by time;
2 - by mileage;
4 - validator=multiplier
min_value min value
max_value max value (excluded)
min_speed min speed
max_speed max speed (excluded)
min_duration min duration
max_duration max duration (included)
validator_id validator sensor id
sensor_id sensor id (for sensor evaluation criterion only)
name any criterion name
penalties penalties
Response
Returns empty object {} if settings saved successfully.
