Localization settings
To set timezone, language, date format or tile density for layers, use the command render/set_locale:
svc=render/set_locale&params={"tzOffset":<uint>,
			      "language":<text>,
			      "flags":<uint>,
			      "formatDate":<text>,
			      "density":<uint>}
Parameters
Name Description Notes
tzOffset timezone
language language (two-lettered code)
flags flags:
0 - metric system of measurement,
1 - US system,
2 - imperial system
optional
formatDate date & time format (see below)
density tile size optional
Date & time format
Parameter Description
%H The hour of the day with leading zero if required (“00” to “23”)
%B The full month name (“January” to “December”)
%b Abbreviated month name (“Jan” to “Dec”)
%m The month of the year with leading zero if required (“01” to “12”)
%l The month of the year between 1-12 (“1” to “12”)
%P Format Persian calendar (“01 Farvardin 1392 00:00:00”)
%A The full day name (“Monday” to “Sunday”)
%a Abbreviated day name (“Mon” to “Sun”)
%E The day of the month with leading zero if required (“01” to “31”)
%e The day of the month between 1 and 31 (“1” to “31”)
%I The hour of the day with leading zero if required (“01” to “12”)
%M The minute of the hour with leading zero if required (“00” or “59”)
%S The seconds of the minute with leading zero if required (“00” to “59”)
%p Displays the A.M./P.M. designator (“AM” or “PM”)
%Y The full four digit year (“1999” or “2008”)
%y The year as a two-digit number (“99” or “08”)
Example:
"formatDate":"%Y-%m-%E %H:%M:%S"
Result:
2013-01-26 12:34:56
Density
Default tile size is 256*256.
Value Tile size Ratio
1 256*256 1
2 378*378 1.5
3 512*512 2
4 768*768 3
5 1024*1024 4
Response
{}	/* empty object if execution successful, if not - error code */
