ru:sidebar:remoteapi:apiref:unit:update_drive_rank_settings [28/09/2016 08:59] stan |
ru:sidebar:remoteapi:apiref:unit:update_drive_rank_settings [03/08/2018 13:07] sden [Изменение параметров оценки качества вождения] |
Строка 3: | Строка 3: | ||
svc=unit/update_drive_rank_settings¶ms={"itemId":<long>, | svc=unit/update_drive_rank_settings¶ms={"itemId":<long>, | ||
- | "driveRank": | + | "driveRank":{ |
- | { | + | "acceleration":[ |
- | "acceleration":[ | + | {"flags":<uint>, |
- | { | + | "min_value":<double>, |
- | "flags":<uint>, | + | "max_value":<double>, |
- | "min_value":<uint>, | + | "min_speed":<uint>, |
- | "max_value":<uint>, | + | "max_speed":<uint>, |
- | "min_speed":<uint>, | + | "min_duration":<uint>, |
- | "max_speed":<uint>, | + | "max_duration":<uint>, |
- | "min_duration":<uint>, | + | "validator_id":<long>, |
- | "max_duration":<uint>, | + | "name":<text>, |
- | "validator_id":<long>, | + | "penalties":<uint>}, |
- | "name":<text>, | + | ... |
- | "penalties":<uint> | + | ], |
- | }, | + | "brake":[ |
+ | {"flags":<uint>, | ||
+ | "min_value":<double>, | ||
+ | "max_value":<double>, | ||
+ | "min_speed":<uint>, | ||
+ | "max_speed":<uint>, | ||
+ | "min_duration":<uint>, | ||
+ | "max_duration":<uint>, | ||
+ | "validator_id":<long>, | ||
+ | "name":<text>, | ||
+ | "penalties":<uint>}, | ||
+ | "turn":[ | ||
+ | "sensor":[ | ||
+ | "sensor_id":<long>, | ||
- | "brake":[ | + | "speeding":[ |
- | { | + | {"flags":<uint>, |
- | "flags":<uint>, | + | "min_value":<double>, |
- | "min_value":<uint>, | + | "max_value":<double>, |
- | "max_value":<uint>, | + | "min_speed":<uint>, |
- | "min_speed":<uint>, | + | "max_speed":<uint>, |
- | "max_speed":<uint>, | + | "min_duration":<uint>, |
- | "min_duration":<uint>, | + | "max_duration":<uint>, |
- | "max_duration":<uint>, | + | "validator_id":<long>, |
- | "validator_id":<long>, | + | "name":<text>, |
- | "name":<text>, | + | "penalties":<uint>}, |
- | "penalties":<uint> | + | ... |
- | ... | + | "harsh":[ |
- | ], | + | {"flags":<uint>, |
- | "turn":[ | + | "min_value":<double>, |
- | { | + | "max_value":<double>, |
- | "flags":<uint>, | + | "min_speed":<uint>, |
- | "min_value":<uint>, | + | "max_speed":<uint>, |
- | "max_value":<uint>, | + | "min_duration":<uint>, |
- | "min_speed":<uint>, | + | "max_duration":<uint>, |
- | "max_speed":<uint>, | + | "validator_id":<long>, |
- | "min_duration":<uint>, | + | "name":<text>, |
- | "max_duration":<uint>, | + | "penalties":<uint>}, |
- | "validator_id":<long>, | + | ... |
- | "name":<text>, | + | ], |
- | "penalties":<uint> | + | "global":{ |
- | }, | + | "accel_mode":<uint> |
- | "sensor":[ | + | |
- | "flags":<uint>, | + | |
- | "min_value":<uint>, | + | |
- | "max_value":<uint>, | + | |
- | "min_speed":<uint>, | + | |
- | "max_speed":<uint>, | + | |
- | "min_duration":<uint>, | + | |
- | "max_duration":<uint>, | + | |
- | "validator_id":<long>, | + | |
- | "sensor_id":<long>, | + | |
- | "name":<text>, | + | |
- | "penalties":<uint> | + | |
- | "speeding":[ | + | |
- | "harsh":[ | + | |
- | "global":{ | + | |
- | "accel_mode":<uint> | + | |
Строка 129: | Строка 116: | ||
| name | любое имя критерия | | | name | любое имя критерия | | ||
| penalties | значение штрафа | | | penalties | значение штрафа | | ||
- | | accel_mode | расчет ускорения по:\\ 0 - GPS+акселерометр;\\ 1 - GPS;\\ 2 - акселерометр. | | ||
Возвращает пустой объект {}, если настройки успешно сохранены. | Возвращает пустой объект {}, если настройки успешно сохранены. |
