en:sidebar:remoteapi:codesamples:batch [23/05/2019 13:07] chdi |
en:sidebar:remoteapi:codesamples:batch [23/05/2019 13:13] chdi [Executing several commands at once] |
Line 51: | Line 51: | ||
- | As we can see from the response, two users are available and their IDs are 648548 and 656124. Let's send them online messages using one request [[../apiref/core/batch|core/batch]]. To send an online messages, use the command **user/update_user_notification**. Its detailed description is given in the chapter [[../apiref/user/update_user_notification]]. | + | As we can see from the response, two users are available and their IDs are 648548 and 656124. Let's send them online messages using one request [[../apiref/core/batch|core/batch]]. To send an online messages, use the command **user/update_user_notification**. We will use different styles for text - parameter "d". |
+ | Its detailed description is given in the chapter [[../apiref/user/update_user_notification]]. | ||
<code> | <code> | ||
Line 71: | Line 72: | ||
"params":{ | "params":{ | ||
"h":"Hi there!", | "h":"Hi there!", | ||
- | "d":";-)", | + | "d":"{\"body\":\"<p style=\\\"text-align: center;\\\"><b style=\\\"text-align: center;\\\"><i style=\\\"text-align: center; color: rgb(0, 0, 0);\\\"><span style=\\\"color:rgb(0,0,255);text-align: center;\\\">Text bold cursive blue color in the centre</span></i></b></p>\",\"head\":{\"c\":39219,\"fs\":\"12\"},\"multiple\":1}", |
"s":"", | "s":"", | ||
"ttl":1359015606, | "ttl":1359015606, | ||
Line 87: | Line 88: | ||
"id": 1, | "id": 1, | ||
"t": 1359013247, | "t": 1359013247, | ||
- | "d": ";-)", | + | "d": {\"body\":\"<span style=\\\"font-size:16px;color:green\\\">New notification with custom text format</span> |
+ | \",\"head\":{\"c\":52428,\"fs\":\"18\"}", | ||
"h": "Hi there!", | "h": "Hi there!", | ||
"s": "" | "s": "" | ||
Line 94: | Line 96: | ||
- | "d": ";-)", | + | "d": "{\"body\":\"<p style=\\\"text-align: center;\\\"><b style=\\\"text-align: center;\\\"><i style=\\\"text-align: center; color: rgb(0, 0, 0);\\\"><span style=\\\"color:rgb(0,0,255);text-align: center;\\\">Text bold cursive blue color in the centre</span></i></b></p>\",\"head\":{\"c\":39219,\"fs\":\"12\"},\"multiple\":1}, |
"s": "" | "s": "" |
