Both sides previous revision Previous revision | Next revision Both sides next revision | ||
en:sidebar:remoteapi:apiref:user:update_user_notification [20/12/2013 12:06] mast |
en:sidebar:remoteapi:apiref:user:update_user_notification [23/12/2013 15:24] mast |
Line 28: | Line 28: | ||
<note important> | <note important> | ||
If **ttl**-param points to the date in past, then notifications trigger only while online (aren't stored on server). ttl -- date in millisecs from 1 Jan 1970. | If **ttl**-param points to the date in past, then notifications trigger only while online (aren't stored on server). ttl -- date in millisecs from 1 Jan 1970. | ||
- | Fill in **id** (any value) even when __callMode: create__ (//to be fixed//). | ||
</note> | </note> | ||
