Differences
en:sidebar:remoteapi:apiref:user:update_item_access [28/01/2013 07:17] zuve |
en:sidebar:remoteapi:apiref:user:update_item_access [29/11/2013 13:31] |
{{indexmenu_n>1}} | |
====== Manage user rights ====== | |
To give user access rights to item use command **user/update_item_access**: | |
<code javascript> | |
svc=user/update_item_access¶ms={"userId":<long>, | |
"itemId":<long>, | |
"accessMask":<long>} | |
</code> | |
===== Parameters ===== | |
^ Name ^ Description ^ | |
| userId | user ID | | |
| itemId | item ID | | |
| accessMask | access mask (see [[../core/check_items_billing#General| Access flags: General]] и [[../core/check_items_billing#Units and unit groups| Access flags: Units and unit groups]])| | |
{} /* пустой объект при удачном выполнении, при неудачном - код ошибки */ | |
</code> | |
