en:sidebar:remoteapi:apiref:token:update [14/12/2017 16:08] stan [Parameters] |
en:sidebar:remoteapi:apiref:token:update [21/12/2020 07:24] chdi [Parameters] |
Line 24: | Line 24: | ||
| app | application name | | | app | application name | | ||
| at | token activation time, UNIX-time:\\ 0 - now | | | at | token activation time, UNIX-time:\\ 0 - now | | ||
- | | dur | token duration after activation, seconds:\\ if 0 -- duration is infinite | | + | | dur | token duration after activation, seconds:\\ max value = 8640000 (100 days) if 0 -- duration is infinite | |
| fl | access flags | | | fl | access flags | | ||
| p | custom parameters, value must be object or an array of objects\\ p:{} is minimal | | | p | custom parameters, value must be object or an array of objects\\ p:{} is minimal | | ||
Line 51: | Line 51: | ||
| 0x1000 | modification of critical data, including messages deletion | | | 0x1000 | modification of critical data, including messages deletion | | ||
| 0x2000 | communication | | | 0x2000 | communication | | ||
- | | -1 | unlimited operation as authorizated user\\ (allows to manage user tokens) | | + | | 0xFFFFFFFF | unlimited operation as authorizated user\\ (allows to manage user tokens) | |
:!: More info you can get [[../format/token|here]]. | :!: More info you can get [[../format/token|here]]. |
